trouble flashing eMMC
The most reliable way to flash the eMMC is indeed to use:
  • on the PinePhone pro, the USB Mass Storage (jump drive) mode of Tow-Boot ("The phone can be started in USB Mass Storage mode by holding the volume up button at startup before and during the second vibration. The LED will turn blue if done successfully. In this mode, the phone will work like a USB drive when connected to a host computer.") (as is mentioned on the video, though you cannot actually see it being done),
  • on the original (A64) PinePhone, a MicroSD card with the dedicated JumpDrive image (download the image and dd it to an empty MicroSD card, or one whose data you do not need anymore, as all data on the MicroSD card will be overwritten and hence wiped by dd) that turns it into a USB mass storage device.
Then you can connect the phone to a computer using a USB C-A or C-C cable and flash it just like a USB stick or an SD card.
Flashing directly from a running image on a MicroSD card is not so safe because you will be copying a running system, unless you copy another image file into the dd'd image beforehand and use that as the dd source on the phone rather than the running system.
trouble flashing eMMC - by TylerBlackberry - 04-11-2023, 11:03 AM
RE: trouble flashing eMMC - by TylerBlackberry - 04-11-2023, 12:36 PM
RE: trouble flashing eMMC - by mikehenson - 04-12-2023, 09:47 AM
RE: trouble flashing eMMC - by Kevin Kofler - 04-13-2023, 05:55 AM
  install iso from sd card to emmc aular 2 429 03-11-2024, 10:24 PM
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,538 05-10-2023, 03:31 AM
Last Post: fxc
  Jumpdrive broken? eMMc broken Uturn 5 1,862 04-21-2023, 12:37 AM
Last Post: Uturn
  This is how you flash to eMMC easily Luke 49 82,509 12-25-2022, 05:13 PM
Last Post: fxc
  emmc formatted by mistake (it no longer appears) elode 5 3,278 07-12-2022, 04:33 AM
Last Post: elode
  My Pine doesn't allow me to install to eMMC on different OS's Kimberley van Buyten 1 1,403 05-31-2022, 04:26 PM
Last Post: fxc
  no emmc after flash ragele 3 2,294 05-30-2022, 04:26 AM
Last Post: fxc
  Flashing gone wrong erg 9 4,541 05-28-2022, 10:52 AM
Last Post: fxc
  eMMC label gilwood 1 2,270 12-31-2021, 06:25 PM
Last Post: moonwalkers
  Can't mount eMMC image on my desktop? nelstomlinson 0 1,319 10-16-2021, 09:30 AM
Last Post: nelstomlinson
