My PinePhone Pro does not read the micro SD card at all.
(03-23-2023, 03:34 PM)tux_life Wrote: Hi!
I tried booting from SD card as indicated here: https://wiki.pine64.org/wiki/PinePhone_Pro#Boot_from_microSD_card_temporarily.
I also tried holding the RE button.
Nothing works and the operating system does not detect any SD card.
The microSD card is inserted all the way...
[Image: gXPySj4G]
[Image: 7GmC3ZWs]
RE button is not necessary in that case, holding "volume down" at boot is sufficient as it seems that you bought your phone after July 2022. Though the OS not detecting the card is not a good sign, booting from it will not work in that case either.
The card looks inserted correctly and it's a very basic functionality which is expected to work, unless something is broken (card, card reader).
Did you try a different card? This one looks like it already went through a lot of things.
RE: My PinePhone Pro does not read the micro SD card at all. - by fxc - 03-23-2023, 06:24 PM
  PinePhone Pro EDL boot by shorting contacts ozkenlc 1 241 05-01-2024, 09:29 AM
Last Post: traut
Thumbs Up Pinephone Pro + Keyboard for sale Jimmy88 2 851 04-22-2024, 08:38 PM
Last Post: AegisWages
  PinePhone only turns on sometimes zvavybir 1 448 03-27-2024, 12:19 PM
Last Post: zvavybir
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 7 1,357 03-24-2024, 02:22 PM
Last Post: zetabeta
Question Screen turning off and booting problems with the Pinephone Pro xnZwJR6vys9a2wm7yWE4 0 256 01-16-2024, 02:38 PM
Last Post: xnZwJR6vys9a2wm7yWE4
  Pinephone Pro LCD and Touchscreen Hobgoblin 8 3,975 01-14-2024, 02:50 PM
Last Post: shifras
  Recurrent problems with broken charger chip on the pinephone/pinephone pro keyboard Jite 4 1,268 11-18-2023, 07:25 AM
Last Post: crocspot
  is it possible to install a pinephone pro mainboard in a pinephone hannescam 7 2,823 08-13-2023, 04:50 AM
Last Post: fxc
  Pinephone pro packet injection for internal wifi chipset covar 1 860 08-13-2023, 04:40 AM
Last Post: fxc
  PinePhone Keyboard won't work. read_kb_reg(PPKB_SYS_CONFIG) needs what? jovval 0 543 07-09-2023, 09:03 PM
Last Post: jovval
