[Megapixels] Flash strobe, pictures viewer and MPCamera error 22
(03-17-2023, 07:17 AM)freelectro Wrote: Hi all,
I'm in bookworm mobian and do all latest available updates/upgrades on repo.
I have megapixels with 1.6.0-1+b1 version.
As suggest, i have installed necessary packages "dcraw" and "imagemagick".
In log, flash strobe is not openned.
Failed to open /sys/class/leds/white:flash/flash_strobe
And when i clicked on picture small icon to launch the rooftop snipers viewer, it returned to me this error.
display-im6.q16: unable to open X server `' @ error/display.c/DisplayImageCommand/412.
Moreover, some camera log give error 22 as described follow.
MPCamera: VIDIOC_SUBDEV_S_FRAME_INTERVAL error 22, Argument invalide
MPCamera: VIDIOC_QBUF error 22, Argument invalide
Thanks a lot for your feedback.
All log megapixels from term are here.
megapixels
Found config file at /usr/share/megapixels/config/pine64,pinephone-1.2.ini
Adding camera rear from config
Adding camera front from config
Initialized OpenGL ES 2.0
TIFF version 20221213
Writing frame to /tmp/megapixels.SXpdil/0.dng
Writing frame to /tmp/megapixels.SXpdil/1.dng
Writing frame to /tmp/megapixels.SXpdil/2.dng
Making thumbnail
Writing frame to /tmp/megapixels.SXpdil/3.dng
Post process /tmp/megapixels.SXpdil to /home/home/Images/IMG20230317080048.ext (save-dng 1)
Flash Strobe Issue:
The error message indicates that the flash strobe is not being opened. This could be due to a hardware or configuration issue. Make sure that your device's camera supports a flash strobe and that it is functioning correctly. Additionally, check the configuration files for Megapixels to ensure that the settings for the flash strobe are properly configured.
X Server Error:
The error message "unable to open X server" suggests an issue with the X server, which is responsible for managing graphical display on Linux systems. Make sure that the X server is running and accessible. If you are running Megapixels from a terminal, try launching it from a graphical user interface (GUI) environment to see if the error persists.
VIDIOC_SUBDEV_S_FRAME_INTERVAL and VIDIOC_QBUF Errors:
These errors indicate problems with video input/output control (VIDIOC) operations. It could be caused by incompatible or incorrect camera drivers or configurations. Make sure that you have the appropriate camera drivers installed and configured correctly for your device. You may need to check the Megapixels documentation or seek support from the Mobian or Megapixels community for further assistance.
RE: [Megapixels] Flash strobe, pictures viewer and MPCamera error 22 - by karensather - 08-30-2023, 03:59 AM
  ModemManager debug mode? (Needed to flash modem) calinb 1 1,261 02-27-2023, 04:18 PM
Last Post: calinb
Exclamation The document viewer Evince cannot be reinstalled anonymous 0 636 09-08-2022, 05:09 AM
Last Post: anonymous
  Megapixels doesn't work Glenn 4 2,889 08-28-2022, 03:19 PM
Last Post: vortex
  Megapixels and Pinhole Zebulon Walton 0 927 06-15-2022, 04:53 PM
  Fast image viewer? vusra 0 823 04-25-2022, 04:09 AM
Last Post: vusra
  Error - megapixels not opening user641 17 10,113 03-29-2022, 03:43 PM
Last Post: bcnaz
  Flatpak error during apt update user641 0 1,171 02-14-2022, 08:35 AM
Last Post: user641
  How to flash a µSD-Card with Balena Etcher walter1950 1 1,344 01-22-2022, 02:06 AM
Last Post: bcnaz
  Waydroid error: not using Wayland. But I am! quixote 7 6,833 01-09-2022, 02:47 PM
Last Post: jsch
  Suddenly, nothing but a backlight and a boot logo flash 3x5co 8 4,204 12-05-2021, 08:24 PM
Last Post: Anna
