Flight mode turns off wifi but not the modem (cellular)
(02-28-2023, 05:10 AM)jojuma Wrote: After hours of trial and error, I flashed the custom firmware (v.0.7.3) onto the modem like described here: https://github.com/the-modem-distro/pinephone_modem_sdk
They also describe how to flash the stock firmware.
<snip>
I'm experiencing problems much like what you had with your PP. I tried to flash v.0.7.3, including with sudo and sudo su, but only got this each time:
$ ./flashall
Sending AT+QFASTBOOT...
                                                  FAILED (remote: 'unknown command')
fastboot: error: Command failed
fastboot: error: cannot load 'appsboot.mbn': No such file or directory
./flashall: 8: exit: Illegal number: Failed to flash the bootloader
What am I missing? I did apt install fastboot adb
The only place I have an appsboot.mbn file is in my archives of the OEM modem firmware (and yes, I did sudo updatedb first):
$ locate appsboot.mbn
/home/mobian/quectel_eg25_recovery-EG25GGBR07A08M2G_01.003.01.003/update/appsboot.mbn
/home/mobian/quectel_eg25_recovery-EG25GGBR07A08M2G_30.006.30.006/update/appsboot.mbn
I'm running mobian. Thanks for any tips or guidance!
Update: I had the source files only (duh!).  It flashed but still no luck getting it to connect to my cell provider's network. Signal strength is normal. It finds the network with ModemManager GUI but will not activate. The SIM card works on my old Moto G4.
RE: Flight mode turns off wifi but not the modem (cellular) - by calinb - 02-28-2023, 01:58 PM
  NomadNet (e2e mesh comms via BT/WiFi/LoRa) reTestability 6 2,730 03-10-2024, 10:03 AM
Last Post: reTestability
  Cellular internet shulamy 6 3,548 09-17-2022, 10:14 AM
Last Post: shulamy
  Manjaro Plasma Beta and Cellular Data Service Fred Zyphal 7 5,228 03-17-2022, 05:50 PM
Last Post: Fred Zyphal
  No wifi with phosh image wave22 3 2,507 02-15-2022, 07:25 AM
Last Post: wave22
  WiFi Calling ? User 22007 5 5,787 07-19-2021, 11:17 PM
Last Post: KNERD
  WiFi fun on a new PinePhone ~Daniel~ 3 3,375 06-30-2021, 07:20 AM
Last Post: mouffa
  inhibit suspend mode Rainer 2 3,156 06-16-2021, 09:15 AM
Last Post: Rainer
  minicom to access quectel modem Rainer 3 3,540 05-20-2021, 05:44 AM
Last Post: wibble
  Dock,launcher in convergent mode 112113101098101077 0 1,439 03-07-2021, 06:38 AM
Last Post: 112113101098101077
  Plasma Mobile airplane / aeroplane mode / mobile off dcinoz 4 3,891 02-25-2021, 03:46 AM
Last Post: dcinoz
