No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED
A semi-update: I learned from the tow-boot documentation that the Pinephone will not automatically load from an SD card unless you hold the volume button down while holding the power button. When I did this, I was able to boot from the installer SD. I'll leave this thread open in case someone has a specific solution to the issue of Mobian not booting. For my purposes, it was enough to re-install.
RE: No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED - by 3x5co - 01-04-2023, 06:46 PM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,070 11-22-2023, 11:46 AM
Last Post: aLoop100o
  Command to test vibration motor? Zebulon Walton 3 2,146 11-12-2023, 08:45 PM
Last Post: zetabeta
  How to check if tow-boot is installed? jojuma 3 985 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 650 09-01-2023, 11:29 AM
Last Post: Mahgue
  4G data on default startup / boot dcinoz 1 860 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 1,361 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 985 03-06-2023, 12:06 PM
Last Post: freelectro
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,238 03-01-2023, 04:45 PM
Last Post: anonymous
  boot gets stuck shortly after disk decryption vortex 8 4,082 02-13-2023, 02:11 AM
Last Post: sharase
  [solved] Black screen at boot time mdk 0 1,026 01-13-2023, 03:33 AM
Last Post: mdk
