Install OpenBSD 7.2 on Pine64+ (2Gb)
Hey there,
anyone managed that ?
My Pine64 was taking dust in a box with an old debian distro on it.
Then I decided I could maybe use it if I could put an OpenBSD on it, to replace another machine I have.
Unfortunately it keeps hanging at different points in the install process and is left in such a way that I have to reflash everything again.
To reach that point I overcame the hurdle of using screen appropriately on my mac (found the best info here and here). In short identifying correctly the serial device to use Smile)
Then I was able to check that that page (explaining how to do with an LTS version) applied easily enough to the Pine64+ if taking appropriate files (not those of the LTS Smile)
And now, I'm kinda stuck and it's bugging me.
Note : I tried to follow the instructions from OpenBSD.org for the PIne64+ but did not quite understand, or they don't work Smile
That paragraph of the arm64 install page :
Firmware which provides an UEFI interface with a Device Tree Blob
(DTB) file or ACPI support is required to boot.  In most cases this is
provided by images of U-Boot 2016.07 or newer on SD/MMC devices or in
SPI flash.  If the miniroot or install images are used, U-Boot and
DTB files are distributed as part of the images.
turned out to be optimistic for example.
Anyway, any help would be appreciated.
That being said I see this section of the forum is very quiet since 2019 Smile
Install OpenBSD 7.2 on Pine64+ (2Gb) - by pierrep - 12-04-2022, 04:35 AM
  NetBSD will does not install to eMMC ronverbs 3 8,259 06-24-2020, 01:07 AM
  FreeBSD on pine64 e-minguez 12 23,261 06-04-2019, 07:44 AM
Last Post: rob933a
  OpenBSD on Pine64 e-minguez 5 10,256 05-24-2019, 03:11 AM
Last Post: Luke
