Pine Phone Pro audio on phone calls: discussion, support and tips
(02-08-2023, 09:02 AM)Piotr Wrote: 1/ My 1st experience was - issue with calls on 4G / Lte .  -> I forced phone to 3G only -> this has helped for connection to be established
2/ i noticed voice was low on regular call , but switching to loudspeaker  mode and then switching off loudspeaker mode was fixing  normal call audio
3/ Then for the quality of the audio (low internal mic sensitivity/gain , low internal speaker, low loudspeaker sound ) you can modify some mic gain , volume parameters in following files (i suggest to make a backup of originals Smile
/usr/share/alsa/ucm2/PinePhonePro/ HiFi.conf    [media playback profile  settings]
/usr/share/alsa/ucm2/PinePhonePro/VoiceCall.conf  [phone call profile setting]
microphone volume setting:
# Set capture volume to 0dB so modem audio doesn't overdrive the ADC
cset "name='ADC Capture Volume' 60"
cset "name='Mono ADC Capture Volume' 99"
speaker volume setting
# Limit amplification factor of earpiece amplifier so sound stays clear
cset "name='Class D SPK Ratio Control' 2.20x"
with above setting Phone call in normal mode works fine for me , but loudspeaker mode is not usable .
hi, any other suggestions for fixing loud (like white noise) whilst talking in a call?  I've followed these without an improvement. My voice sounds as I am in a rave but I am only inside my hole.
RE: Pine Phone Pro audio on phone calls: discussion, support and tips - by tookmeayear - 05-10-2023, 08:26 AM
  Battery life thread: discussion, support and tips apink 7 2,189 Yesterday, 12:53 PM
Last Post: Rednoise
Question Calls: ALSA UCM config not making a difference with volume lightwo 5 249 05-13-2024, 01:57 PM
Last Post: alaraajavamma
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 16 2,402 04-28-2024, 01:52 AM
Last Post: diederik
  Guide to Suitable Phone State Borealid 19 11,089 09-18-2023, 07:00 AM
Last Post: robocone
  Phone Attitude(Device orientation) lurkadillian 2 1,100 06-22-2023, 08:12 PM
Last Post: lurkadillian
  Any tips to improve the audio quality of calls on the PinePhone Pro? tux_life 2 1,598 05-12-2023, 12:58 PM
  Mobian has new separate packages to support the PinePhone Pro mburns 22 7,723 04-10-2023, 12:02 PM
Last Post: mburns
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 1,876 02-18-2023, 06:14 PM
Last Post: fxc
  [Mobian] No return from locked phone arno_nuehm 1 1,072 02-06-2023, 07:57 AM
Last Post: arno_nuehm
  Making and receiving calls via command line Zotax 0 855 01-28-2023, 12:19 PM
Last Post: Zotax
