new to pine phone and struggling
i installed mobian and it's a much better experience than manjaro, I'd highly recommend it over the pre-installed manjaro. Eg, vim is pre-installed, neofetch is easily installed using the usual commands for debian/ubuntu etc. It seems more user intuitive and welcoming
in case it's useful to anyone i'll explain what i did, even though it's covered in the wiki very nicely.
problem is there are lots of good videos about the pinephone and it's not obvious to a noob which are relevant. Eg, this is an excellent video ie very clearly explained: https://www.youtube.com/watch?v=66Orpoxs...el=myLinux, but it's not relevant if you have the pinephone pro. For the pinephone pro explorer purchased after july2022, you don't need to worry about tow boot, jumpdrive ...
-you need a fresh sd card, solely for the purpose
-get image from here: https://wiki.pine64.org/wiki/PinePhone_P...ses#Mobian, ie img.gz file from here: https://images.mobian-project.org/pinephonepro/weekly/
-download it, then: gunzip mobian-pinephone-phosh-YYYYMMDD.img.gz [note the mobian wiki says "We recommend downloading pre-built images for installation", not the 'installer']
-as in the video linked above, run 'lsblk' before and after connecting the sd card to the laptop, so you get the dd command below correct
-i used method 3 from: https://wiki.mobian-project.org/doku.php...tall-linux
-ie, flash with the following command: sudo dd bs=1M if=mobian-pinephone-phosh-YYYYMMDD.img of=/dev/TARGETSTORAGEDEVICE status=progress [this can take a while, hence use ‘progress’]
-run 'sync' [as he explains in the video above, or maybe use ‘conv=fsync’ as per the wiki?]
-then, as it says on the wiki: "To boot to an SD card, place the SD card in your PinePhone Pro and turn it on. The phone will vibrate once. At this point, hold down the volume down button until you feel the device vibrate again then release the button. The LED color should change to blue and your display should remain black for a few seconds."
-you will come to the log in screen and the password is 1234
new to pine phone and struggling - by neverdimed - 11-22-2022, 06:41 AM
RE: new to pine phone and struggling - by shulamy - 11-22-2022, 07:19 AM
RE: new to pine phone and struggling - by shulamy - 11-22-2022, 09:36 AM
RE: new to pine phone and struggling - by fxc - 11-22-2022, 01:16 PM
RE: new to pine phone and struggling - by shulamy - 11-22-2022, 11:19 PM
RE: new to pine phone and struggling - by neverdimed - 11-25-2022, 05:01 PM
  Looking for the "non-phone" OS wakyct 7 1,315 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 5,108 03-11-2024, 10:42 PM
Last Post: Emelia525
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 972 01-09-2024, 07:02 PM
Last Post: britelite
  Pine company idea aular 9 1,913 12-07-2023, 12:32 AM
  Can the Pine Phone be serviced and updated remotely? profileyourcity 3 1,119 10-02-2023, 05:19 PM
  UBports on pine phone? robb777 16 3,829 09-01-2023, 04:26 AM
Last Post: gregb49
  US Cell Phone Service Providers with prices and phone numbers - UPDATED jovval 0 744 07-01-2023, 01:25 AM
Last Post: jovval
  Loving my pine phone after about a year of not undata 0 718 05-11-2023, 02:23 PM
Last Post: undata
  New Phone Opening Issues LuluFrance 5 2,205 03-15-2023, 05:33 AM
Last Post: anonymous
  pine phone external speaker AnAbolitionist 9 3,482 02-08-2023, 01:11 AM
Last Post: robb777
