PinePhone carrier support in Hungary
(12-14-2022, 11:52 AM)dachalife Wrote: Telenor & online is still functional for NE Hungary (Image attached).
Edit: I can't connect through the yettel one, just tried.
According to multiple Yettel employees, the name doesn't really matter (so it can be Telenor, or Yettel, or probably anything). The important part is the address of the access point.
You probably have a voice based plan, which means that both calls and mobile data are included in your subscription. Then you have to use the “online” access point.
I have a data-only plan, which doesn't include calls, only mobile data. This is most commonly used in wireless routers, and provides the same data bandwidth for a cheaper price (because calls are excluded). I use a SIM card with this subscription in my PinePhone, because I use a separate phone as the main driver for calls (unfortunately, currently the PinePhone is unreliable for voice calls). I have to use the “net” access point for this subscription.
Yettel Hungary uses separate access points for these two plans, and setting the other on either won't work.
The data-only APN setting is not mentioned on their website, probably to avoid confusion, as this is a rarely used subscription. I got the info from their customer service employees.
PinePhone carrier support in Hungary - by notramo - 11-08-2022, 10:35 AM
RE: PinePhone carrier support in Hungary - by notramo - 12-14-2022, 12:18 PM
  my pinephone melted norayr 6 800 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,073 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  Supported Carrier and Modem Bands NachoMomma 4 1,564 03-23-2024, 02:00 PM
  various tricks to open the pinephone shengchieh 2 692 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 323 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,769 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,610 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,374 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 962 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,063 08-23-2023, 03:25 AM
Last Post: Kali
