Arduino IDE on Pine64
Big Grin
Hi all!
This is an update although specifically for the Pinebook I just received, it might work on the Pine64+.
I just ran the update scripts on /usr/local/sbin/ (kernel,uboot and package) to update to version 0.5.5 on my Pinebook 14".
I gathered some information from other forums and this is my small list of instructions I followed to make Arduino IDE 1.8.3 work on the Pinebook (compiling and loading).
Info to install Arduino IDE in Pine64
https://forum.arduino.cc/index.php?topic=400808.0
1. Download the ARM version of Arduino IDE (1.8.3)
2. Run the ./install script in the folder arduino-1.X.X
3. Add armhf architecture support
sudo dpkg --add-architecture armhf
4. Install some 32 bit libraries (armhf)
sudo apt-get install libxtst6:armhf
 sudo apt-get install libxrender1:armhf
 sudo apt-get install libxi6:armhf
 sudo apt-get install openjdk-8-jre:armhf
 sudo apt-get install libxft2:armhf
5. Set permissions for accessing serial port:
 sudo usermod -a -G dialout pine64
 sudo chmod a+rw /dev/ttyACM0
It took a while to open the app, but once opened it was fast and compiled very fast.
Still have to try this on the Pine64+.
Arduino IDE on Pine64 - by jrullan - 07-14-2016, 03:24 PM
RE: Arduino IDE on Pine64 - by MarkHaysHarris777 - 07-14-2016, 05:03 PM
RE: Arduino IDE on Pine64 - by tllim - 07-14-2016, 05:10 PM
RE: Arduino IDE on Pine64 - by martinayotte - 07-15-2016, 07:55 AM
RE: Arduino IDE on Pine64 - by dkryder - 07-15-2016, 08:09 AM
RE: Arduino IDE on Pine64 - by martinayotte - 07-16-2016, 09:30 AM
RE: Arduino IDE on Pine64 - by tllim - 07-16-2016, 07:57 PM
RE: Arduino IDE on Pine64 - by illustris - 07-17-2016, 01:40 AM
RE: Arduino IDE on Pine64 - by martinayotte - 07-17-2016, 07:29 AM
RE: Arduino IDE on Pine64 - by jrullan - 07-17-2016, 06:40 PM
RE: Arduino IDE on Pine64 - by martinayotte - 07-18-2016, 07:31 AM
RE: Arduino IDE on Pine64 - by jrullan - 07-18-2016, 06:20 PM
RE: Arduino IDE on Pine64 - by Zoidiano0 - 08-01-2016, 07:31 PM
RE: Arduino IDE on Pine64 - by tllim - 08-04-2016, 10:37 PM
RE: Arduino IDE on Pine64 - by victagayun - 10-09-2016, 07:42 AM
RE: Arduino IDE on Pine64 - by jrullan - 07-05-2017, 07:44 AM
RE: Arduino IDE on Pine64 - by pfeerick - 07-05-2017, 08:38 PM
  Programming languages support under PINE64 baryluk 6 15,123 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 7,331 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 28,932 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 4,967 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 7,583 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 43,144 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 3,754 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 10,987 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 4,319 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 46,808 10-26-2017, 05:51 PM
Last Post: gregjo
