Arduino IDE on Pine64
(07-16-2016, 09:30 AM)martinayotte Wrote: I gave it a try myself, and got the error. I figured out that was caused by the fact that all those binaries are 32bits, and this cause comptibility issues running on arm64.
I've tried to add some 32bits libs, but it quickly becomes a nightmare since even X11 32 bits version are required.
So, I've prefer to go the other way around : get rid of 32 bits and use 64 bits Java already present on PineA64.
I had to replace the libastylej.so by the 64bits version installed with apt-get, and also the liblistSerialsj.so that I had to compile from sources.
I then got the IDE up and running, but the AVR compiler still 32 bits, so I will have to continue digging, but for now, I don't have time.
To be continued ...
Thanks on the exploring and looking forward to have Arduino IDE runs on Pine64. When we implemented the Arduino shield adapter, I will send one free board and several sensor adapters to you.
Arduino IDE on Pine64 - by jrullan - 07-14-2016, 03:24 PM
RE: Arduino IDE on Pine64 - by MarkHaysHarris777 - 07-14-2016, 05:03 PM
RE: Arduino IDE on Pine64 - by tllim - 07-14-2016, 05:10 PM
RE: Arduino IDE on Pine64 - by martinayotte - 07-15-2016, 07:55 AM
RE: Arduino IDE on Pine64 - by dkryder - 07-15-2016, 08:09 AM
RE: Arduino IDE on Pine64 - by martinayotte - 07-16-2016, 09:30 AM
RE: Arduino IDE on Pine64 - by tllim - 07-16-2016, 07:57 PM
RE: Arduino IDE on Pine64 - by illustris - 07-17-2016, 01:40 AM
RE: Arduino IDE on Pine64 - by martinayotte - 07-17-2016, 07:29 AM
RE: Arduino IDE on Pine64 - by jrullan - 07-17-2016, 06:40 PM
RE: Arduino IDE on Pine64 - by martinayotte - 07-18-2016, 07:31 AM
RE: Arduino IDE on Pine64 - by jrullan - 07-18-2016, 06:20 PM
RE: Arduino IDE on Pine64 - by Zoidiano0 - 08-01-2016, 07:31 PM
RE: Arduino IDE on Pine64 - by tllim - 08-04-2016, 10:37 PM
RE: Arduino IDE on Pine64 - by victagayun - 10-09-2016, 07:42 AM
RE: Arduino IDE on Pine64 - by jrullan - 07-05-2017, 07:44 AM
RE: Arduino IDE on Pine64 - by pfeerick - 07-05-2017, 08:38 PM
  Programming languages support under PINE64 baryluk 6 12,447 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 5,963 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 24,651 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 4,077 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 6,051 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 35,621 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 3,134 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 8,727 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 3,660 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 37,606 10-26-2017, 05:51 PM
Last Post: gregjo
