keyboard case charging but not typing
(02-01-2023, 05:32 AM)theResonant Wrote: I ended up ordering a new PPKB. The new one works perfectly, the old one doesn't. In my case it looks like it's a physical issue (I'm on postmarketOS). I'll try to debug the old one anyway.
Did you ever get round to debugging your keyboard unit? Mine has just stopped typing on both a PinePhone and a Pro. So I doubt that it is a driver issue.
I replaced the circuit board earlier this year after an overheating issue when charging the summer before and all seemed to be well after that. Maybe I should just order another circuit board.
Running Mobian on both phones.
I just ran sudo dmesg | grep key
[    0.289617] Initialise system trusted keyrings
[    0.300614] Asymmetric key parser 'x509' registered
[    2.515438] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    3.345855] arm_scpi: module verification failed: signature and/or required key missing - tainting kernel
[    3.586007] pinephone-keyboard 2-0015: Found firmware version 1.0 features 0xf
[    7.217923] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
This is a different result when compared to an earlier post in this thread where the keyboard was not found.
RE: keyboard case charging but not typing - by grump_fiddle_reinstall - 09-02-2023, 05:12 AM
  Case for Pinephone totilele 13 7,727 04-11-2024, 11:48 AM
Last Post: gramonyl
  Slip/Zippered Case for PP/KB? jakfish 0 315 03-03-2024, 04:55 PM
Last Post: jakfish
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 11,302 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 460 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,326 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 483 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,313 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 554 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 653 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,077 10-20-2023, 04:11 PM
Last Post: mburns
