No boot after Manjaro flash
OK, you are right, somehow the SPI has an auyfan SPI uboot on it
the SPI chip is labeled (on mb) U18
notch
1....8
2....7
3---6
4...5
4 = gnd,, 8 = 3V,,, 6=clock,,, you could verify with DVM
next to reset button is "recovery" button, this is supposed to short clock to ground
you could also verify this with DVM
So, with a for sure bootable SD in, hold recovery button 5+ sec during startup
then install mtd-utils,,,, mtd_debug info /dev/mtd0 ; mtd_debug erase /dev/mtd0 0 16777216
if the button is flakey (known problem), wiggle as you push, or else use fine pointed tweezers to short 6->4
if the points are sharp, less chance of tweezer slipping
All this from before starup ,, for 5 seconds
No boot after Manjaro flash - by PBcurry - 09-21-2022, 01:44 PM
RE: No boot after Manjaro flash - by wdt - 09-21-2022, 10:57 PM
RE: No boot after Manjaro flash - by wdt - 09-23-2022, 09:20 AM
RE: No boot after Manjaro flash - by wdt - 09-24-2022, 09:34 AM
RE: No boot after Manjaro flash - by PBcurry - 09-25-2022, 08:46 AM
RE: No boot after Manjaro flash - by wdt - 09-25-2022, 11:01 PM
RE: No boot after Manjaro flash - by bburdette - 09-27-2022, 08:34 AM
RE: No boot after Manjaro flash - by wdt - 09-27-2022, 08:52 AM
RE: No boot after Manjaro flash - by bburdette - 09-27-2022, 10:57 AM
RE: No boot after Manjaro flash - by bburdette - 10-02-2022, 12:19 PM
RE: No boot after Manjaro flash - by ky56 - 10-03-2022, 03:00 PM
RE: No boot after Manjaro flash - by wdt - 10-03-2022, 08:33 PM
  Manjaro versions bad and good gilwood 0 267 02-12-2024, 05:03 PM
Last Post: gilwood
  uboot wont boot to SD card after upgrade jbradley419 7 895 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 303 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,277 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 712 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 605 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,221 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,919 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 813 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,974 06-14-2023, 07:20 AM
