No boot after Manjaro flash
I have a serious trouble with my Pinebook pro. There is no boot possible even on SD card.
Initial state : Pinebook pro boot well on emmc with Manjaro  (there were conflicts for updates in this older version of Manjaro, that’s why I wanted a new installation )
1) I boot on SD card with a Manjaro.
2) I update manjaro-flash on the SD card and run it.
3) I put a USB key that contains the image  Manjaro-ARM-kde-plasma-pbpro-22.08.img.xz
4) I tell arm-flash the location of the image and click on install. It runs and indicates a progress of the installation on the emmc (several gigabytes).
5) I turn off the machine and remove the SDCard.
6) I turn on the Pinebook pro, and absolutely nothing is happening, no LED lights up, everything stays off.
So I decided to remove the emmc memory and boot on the previous SDCard.
I did several tests by pressing the power button for a long time or not.
I also pressed the reset button on the motherboard.
The computer seems dead because there is not even a light that turns on (I specify that it is plugged into an electrical outlet).
Can a reinstall be forced with UART mode and serial cable for example?
Thank you if you have an idea.
No boot after Manjaro flash - by PBcurry - 09-21-2022, 01:44 PM
RE: No boot after Manjaro flash - by wdt - 09-21-2022, 10:57 PM
RE: No boot after Manjaro flash - by wdt - 09-23-2022, 09:20 AM
RE: No boot after Manjaro flash - by wdt - 09-24-2022, 09:34 AM
RE: No boot after Manjaro flash - by PBcurry - 09-25-2022, 08:46 AM
RE: No boot after Manjaro flash - by wdt - 09-25-2022, 11:01 PM
RE: No boot after Manjaro flash - by bburdette - 09-27-2022, 08:34 AM
RE: No boot after Manjaro flash - by wdt - 09-27-2022, 08:52 AM
RE: No boot after Manjaro flash - by bburdette - 09-27-2022, 10:57 AM
RE: No boot after Manjaro flash - by bburdette - 10-02-2022, 12:19 PM
RE: No boot after Manjaro flash - by ky56 - 10-03-2022, 03:00 PM
RE: No boot after Manjaro flash - by wdt - 10-03-2022, 08:33 PM
  Manjaro versions bad and good gilwood 0 247 02-12-2024, 05:03 PM
Last Post: gilwood
  uboot wont boot to SD card after upgrade jbradley419 7 815 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 288 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,223 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 687 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 585 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,174 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,867 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 799 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,937 06-14-2023, 07:20 AM
