(01-06-2023, 07:59 PM)AnAbolitionist Wrote: there seems to be a problem with the connection between the contacts in the frame and the circuit board, tightening the screws worked for a bit, but sound is dead again. The same thing is happining to all 3 of my pine phones, and even the pinphone pro.
Opening the device (including mid-frame) and readjusting the cable and contacts should be sufficient. That can occasionally happen.
Usually we refer to the speaker on top as the "earpiece speaker" and the speaker on the bottom as "speaker", so mind that speaking about an "external speaker" is a bit misleading here. External speakers would be connected via the audio jack.
(01-07-2023, 07:22 AM)Zebulon Walton Wrote:(09-18-2022, 05:56 PM)AnAbolitionist Wrote: I have 3 pinephones, running manjero, and mobian all 3 phones the external speaker has died, where can I get replacement speakers that can handle what the pinephone puts out.
I have a note here suggesting this speaker as a replacement, but I have not had any problems with my Pinephone speaker so have not tried it:
https://www.walmart.com/ip/Unique-Bargai.../171945776
(09-18-2022, 05:56 PM)AnAbolitionist Wrote: Rest of the phone works and bluetooth is getting better.
Do you have bluetooth audio working? I've tried my phone with a few different bluetooth audio devices and all I get out of them is a loud buzz when they connect. Have tried with Mobian and Arch.
The following speakers would be compatible: https://wiki.pine64.org/wiki/PinePhone#S...NE64_store
But it's unlikely a defective speaker and rather a contact issue, which can be fixed by readjusting the cables and contacts.
