boot gets stuck shortly after disk decryption
This problem is expected to be resolved in v0.67.1-1, which is currently in the works.
subway surfers
RE: boot gets stuck shortly after disk decryption - by sharase - 02-13-2023, 02:11 AM
  Chatty Matrix Decryption Key jojuma 2 305 02-26-2024, 12:48 PM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,080 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 989 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 654 09-01-2023, 11:29 AM
Last Post: Mahgue
  4G data on default startup / boot dcinoz 1 863 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 1,368 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 986 03-06-2023, 12:06 PM
Last Post: freelectro
  [solved] Black screen at boot time mdk 0 1,030 01-13-2023, 03:33 AM
Last Post: mdk
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 1,023 01-04-2023, 06:46 PM
Last Post: 3x5co
  Does tow-boot allow periodic wake from suspension to check for notifications? DrPlamsa 4 2,727 12-31-2022, 10:56 AM
Last Post: DrPlamsa
