No Power or Reset buttons
(07-10-2016, 01:23 PM)Ghost Wrote:
(07-10-2016, 11:09 AM)corymp Wrote: I received my Kit on Friday. But I received no microSd card. and also, there are no power or rest buttons soldered to the board (I can see clearly where they should be). Also, one button came loose in the package. It fits where the power or reset buttons would go, though there is no trace of solder indicating that it was never attached to the board, just loose in the package. Am I responsible for soldering the button to the board?
Regarding the microSd.. Am I supposed to have received one? I cannot get the thing to boot. I get nothing from hdmi whin I plug the board in(I get a red light on the board and that's it).
I also have the LCD touch display but get nothing on that either.
Many thanks in advance!
Yes, you are supposed to solder the switch yourself. The plan was to have it soldered to the board, but enough backers objected that it was decided to add the switch as an extra you would attach yourself.
You would only have gotten a microSD card if you chose a pledge tier that included a microSD on kickstarter, or selected one via the Pine shop when you placed your order.
You will need to get an operating system on a microSD card in order to get an image on the LCD screen. You will also need to connect up the LCD screen correctly.
OK, sounds good. Soldering the switch is no issue at all. But why was only one button included?
No Power or Reset buttons - by corymp - 07-10-2016, 11:09 AM
RE: No Power or Restet buttons - by Ghost - 07-10-2016, 01:23 PM
RE: No Power or Restet buttons - by corymp - 07-10-2016, 03:55 PM
RE: No Power or Restet buttons - by pfeerick - 07-11-2016, 02:49 AM
RE: No Power or Restet buttons - by Ghost - 07-11-2016, 04:42 AM
RE: No Power or Restet buttons - by koda - 07-11-2016, 03:05 AM
RE: No Power or Restet buttons - by ussy7861 - 07-20-2016, 09:14 AM
RE: No Power or Restet buttons - by CaptainZalo - 07-20-2016, 11:12 AM
  New RockPro64 Power Up Problem enorbet2 7 5,207 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 1,874 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 1,956 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 2,451 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 12,639 03-12-2021, 07:08 PM
Last Post: cmicallef
  reset postmarket os to factory specifications jmak 2 4,486 10-02-2020, 08:30 PM
Last Post: SwordfishII
  howto power hdd via usb3 on rockpro64 hanscees 2 5,144 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,810 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 7,179 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 2,570 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
