Pine A64 does only boot with Android 5.1
Thank you tophneal for your reply.
Using the 2.0 port and rufus did work only for Armbian 22.05 Jammy XFCE. Didn't try it with android.
I can not tell what the difference between this combination and the 3.0/Etcher como is, but that worked out.
Of course there is another "but". The problem here is, that i'm stuck with the cli in armbian jammy.
I doublechecked if i downloaded the desktop-version, and i did, but it did boot in the cli instead of a gui. So i did set up the cli-version i.e. Upgrade the system.
I also, and i think that might caused the issue, tried to set up a password. Since this Pine is just ment to stream Netflix on my tv once in a while so that i dont have to use my old, big and loud laptop, armbian rejected my good old "1234" password as too simple. After 3 new tries of using Upper letters, digits and specials, i got logged in as root. While a cli is very good for server purposes, it is not very practical for gui-based purposes.
Shouldn't it boot in gui-mode to setup the OS on the first place? I read in a forum, you can run apps with a gui from the cli by typing "explore display=:0 (or any specific number)". I gave it a shot and nothig happens. Not a supprise.
What am i doing wrong here?
RE: Pine A64 does only boot with Android 5.1 - by Dude - 06-28-2022, 01:49 AM
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,696 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 644 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64+ vs LCD do not boot DDS 3 6,062 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 3,398 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 4,556 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 7,880 12-06-2020, 03:53 PM
Last Post: junkyj753
Exclamation Can't boot when SD card inserted kivox 5 8,166 03-15-2020, 06:00 AM
Last Post: kivox
  Node Red on the Pine DonFL 0 2,805 12-16-2019, 04:21 PM
Last Post: DonFL
Photo Pine A64+ from Kick starter running Pi-Hole netHolio 0 3,274 12-02-2019, 09:36 PM
Last Post: netHolio
  Boot from HDD via usb BnEc 1 3,758 11-29-2019, 04:39 AM
Last Post: evilbunny
