Booting Quartz64 Model B
thanks again for all the assistance! that gets me further (up to mounting the file system), with another kernel panic:
:: performing fsck on '/dev/mmcblk0p5'
rootfs: clean, 33904/917504 files, 177393/3666688 blocks
:: mounting '/dev/mmcblk0p5' on real root
[    2.861970] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
:: running cleanup hook [udev]
/sbin/init: error while loading shared libraries: /usr/lib/libse[    3.001700] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
ccomp.so.2: file too short
[    3.002834] CPU: 1 PID: 1 Comm: init Not tainted 5.16.13-1-aarch64-ARCH #1
[    3.003639] Hardware name: Pine64 RK3566 Quartz64-B Board (DT)
[    3.004151] Call trace:
[    3.004367]  dump_backtrace+0x0/0x1cc
[    3.004703]  show_stack+0x18/0x24
[    3.004997]  dump_stack_lvl+0x68/0x84
[    3.005324]  dump_stack+0x18/0x34
[    3.005619]  panic+0x138/0x308
[    3.005892]  do_exit+0x3e8/0x3ec
[    3.006182]  do_group_exit+0x38/0xa0
[    3.006498]  __arm64_sys_exit_group+0x18/0x20
[    3.006883]  invoke_syscall+0x48/0x114
[    3.007216]  el0_svc_common.constprop.0+0x44/0xfc
[    3.007629]  do_el0_svc+0x28/0x90
[    3.007925]  el0_svc+0x28/0x80
[    3.008197]  el0t_64_sync_handler+0xa4/0x130
[    3.008575]  el0t_64_sync+0x1a0/0x1a4
[    3.008903] SMP: stopping secondary CPUs
[    3.009255] Kernel Offset: disabled
[    3.009562] CPU features: 0x20,00000203,46600e46
[    3.009968] Memory Limit: none
[    3.010242] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00 ]---
i would think if the `fsck` succeeds the SD card / interface is okay, but will try with another cleanly formatted card in case it's some error in the copying over
Edit: swapped SD cards (from a 10MB/s SDHC UHS class 1 to a 30MB/s SDXC UHS class 3), setup -exactly- the same (i wrote a script) and now we _seem_ to be up and running
Booting Quartz64 Model B - by Jojo120120 - 06-25-2022, 11:33 AM
RE: Booting Quartz64 Model B - by igorp - 06-26-2022, 09:30 AM
RE: Booting Quartz64 Model B - by Jojo120120 - 07-01-2022, 05:40 AM
RE: Booting Quartz64 Model B - by igorp - 07-07-2022, 10:57 AM
RE: Booting Quartz64 Model B - by ryankurte - 07-15-2022, 12:25 AM
RE: Booting Quartz64 Model B - by CounterPillow - 07-15-2022, 09:17 AM
RE: Booting Quartz64 Model B - by ryankurte - 07-16-2022, 07:36 PM
RE: Booting Quartz64 Model B - by t4_4t - 07-17-2022, 04:43 AM
RE: Booting Quartz64 Model B - by CounterPillow - 07-17-2022, 10:08 AM
RE: Booting Quartz64 Model B - by ryankurte - 07-17-2022, 04:01 PM
RE: Booting Quartz64 Model B - by CounterPillow - 07-17-2022, 11:35 PM
RE: Booting Quartz64 Model B - by ryankurte - 07-18-2022, 10:39 PM
RE: Booting Quartz64 Model B - by CounterPillow - 07-19-2022, 03:09 AM
RE: Booting Quartz64 Model B - by shaggy013 - 07-20-2022, 04:23 AM
RE: Booting Quartz64 Model B - by balbes150 - 01-23-2023, 03:31 AM
  Quartz64 seeming died Darin755 0 157 01-19-2024, 07:29 PM
Last Post: Darin755
  Quartz64 model a neither booting nor resetting without pressing reset button aleix 2 1,190 08-24-2023, 04:52 AM
Last Post: aleix
  Thoughts on repairs for a Quartz64-B beepy 1 793 08-02-2023, 05:02 PM
Last Post: beepy
Question Li-Pol QUARTZ64 Model-B vs Model-A polrus 1 768 07-13-2023, 10:36 PM
  can't get quartz64-A working jyoung 14 4,489 04-29-2023, 04:41 PM
Last Post: diederik
  Trustzone support for QUARTZ64 capablegh 13 7,093 04-28-2023, 01:58 AM
Last Post: NCLI
  quartz64 model b 2x20 max power proj964 1 1,556 10-23-2022, 05:32 AM
Last Post: CounterPillow
  quartz64 model b 2x20 pin header proj964 1 1,502 10-23-2022, 05:21 AM
  JTAG/SWD on Quartz64 model A capablegh 4 4,780 10-03-2022, 03:16 PM
Last Post: fatalfeel
Tongue Trying to get Quartz model A working fasani 2 2,224 09-17-2022, 06:43 AM
Last Post: balbes150
