Should I just never use the PP keyboard?
My PP keyboard initially worked well enough to be usable when I initially received it at the beginning of this year (I was an early adopter). Took me a few months to figure out the shim so that the battery in the keyboard could charge the PP. When June came around, I started having troubles that appeared to be related to the linux kernel (my guess) not recognizing the PP keyboard. Although the keys worked well enough for basic typing, the PP did not recognize the battery in the keyboard and would not charge. About once a week, I placed the PP into the keyboard to see if a software update applied any fixes.
Note: When the PP was in the keyboard, I only used the usb-c port in the keyboard for charging.
A recent update restored the PP ability to see the keyboard battery and the charging icon appeared when I plugged a usb-c cable into the PP keyboard usb-c port. After about 5 or 10 minutes of charging, the bottom of the keyboard near the usb-c port became quite hot and the amount of charge didn't seem to change. I removed the usb-c cable from the PP keyboard to stop charging and removed the PP from the keyboard.
Note: I have a PPP (running Manjaro KDE instead of Mobian) and the same issues exist with it.
So, I don't use the PP keyboard except to test whether a software update applied any fixes to address the issues I have with it. I do hope the PP keyboard will become usable some day. If not, the PP keyboard will be a disappointment; however, I still like the PP and PineTime very much. When I move over to using the PPP on a full time basis, I expect to like that product too.
RE: Should I just never use the PP keyboard? - by drh - 09-08-2022, 12:53 AM
  keyboard case charging but not typing new2pinephone 18 5,811 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 8,750 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 433 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,193 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 456 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,246 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 524 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 620 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,025 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 834 10-11-2023, 09:03 AM
Last Post: elof
