Should I just never use the PP keyboard?
Don't take this as an advice, because I don't know electronics and it may damage your phone and keyboard!
But I did a simple test using a basic multimeter to probe the 3 pins on the keyboard that connect to the pins on the phone: 5v, ground and DCIN (https://wiki.pine64.org/wiki/PinePhone#Pogo_pins). The keyboard was connected to an old PC to charge a bit while doing the test.
For mine I got values as high as 5 which seemed within spec (for one or both of 5v and DCIN pins - I didn't keep a proper record). And when I hold the button on the keyboard for 15 seconds I got some low values (below 2V).
For easy measurement, I opened the keyboard to it's fullest extend (180 degrees) and laid it on a table , because otherwise it was unstable and I got wrong values most of the time.
And as a side note: the battery on the phone and on the keyboard were depleted overnight and they have at most 0-1%, so I'll wait for a few hours before I can turn it on. I'm using the shim hack: 3 pieces of thick paper (each folded at least once) to make contact. Smile
RE: Should I just never use the PP keyboard? - by bosi564 - 09-04-2022, 03:59 AM
  keyboard case charging but not typing new2pinephone 18 6,001 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 10,673 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 457 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,292 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 479 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,296 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 548 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 647 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,064 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 878 10-11-2023, 09:03 AM
Last Post: elof
