Should I just never use the PP keyboard?
(09-03-2022, 02:11 PM)bosi564 Wrote: I've had similar problem.
It's mentioned above, but also in the wiki - try to "squeeze" or "press" the place where screen and the pogo pins meet. If the
keyboard is being charged (or it's fully charged) and if the drivers are new - the phone should report it's charging now. If that happens - you can try to fix the loose contact with the shim trick described here: https://wiki.pine64.org/wiki/PinePhone_(...er_contact
Also, (i'm not sure if it'll be necessary) try to press the keyboard button to activate the charging functionality if for some reason, the board's firmware decided not to try to charge the phone.
I should report that I use mine regularly since a few months ago. I've seen "the sticky keys" issue before, but not recently as far as I can remember.
I don't think that's going to help my keyboard, unfortunately, as it was working fine for months and just stopped. I've tried squeezing it so hard I was worried I might damage it. Nothing. Also when I used to charge the keyboard it would get very warm. Now when it's plugged in it doesn't warm up at all, suggesting little to no charge going in. I may try to shim the pogo pins as I have nothing to lose but I don't see how it could help in this case. Sad
I'm contemplating opening the keyboard up and seeing if I could take the battery out and replace it with another smaller battery and charging circuit, separate from the keyboard circuitry, but I'm not sure how I would power the keyboard in that setup. I may just buy another keyboard but I'm disappointed how many people seem to be having similar problems to be honest.
RE: Should I just never use the PP keyboard? - by acid andy - 09-03-2022, 03:42 PM
  keyboard case charging but not typing new2pinephone 18 6,045 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 11,090 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 458 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,313 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 481 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,308 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 552 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 649 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,074 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 885 10-11-2023, 09:03 AM
Last Post: elof
