Should I just never use the PP keyboard?
Wow, that does suck. Personally, I would remove the keys from the keyboard and see what might be causing them getting stuck. Maybe remove one keycap?
Someone fixed the top row with some extra paper (or extra 3D-printed rings): https://avery.cafe/blog/a-quick-fix-for-...s-top-row/
Maybe something similar will work for you?
Are all the keys getting stuck?
About the battery inside the PPKB - it should be safe to use your keyboard, but treat the USB port of the phone as if it doesn't exist anymore, as you said. There's some extra info here about those stories you mentioned: https://www.pine64.org/2022/05/31/may-up...-the-wait/
Personally, if I would have received your PPKB instead of mine, I would have wasted an unjustifiably long time trying to hack it to work, then give up on it and swallow the cost if it didn't work at all. I might have even ordered a second PPKB, if other people said it's only a defective one. But I'm desperate for keyboards on phones, so don't take my advice too seriously.
RE: Should I just never use the PP keyboard? - by theResonant - 06-17-2022, 04:13 PM
  keyboard case charging but not typing new2pinephone 18 5,890 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 9,495 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 439 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,229 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 460 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,264 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 528 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 626 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,038 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 848 10-11-2023, 09:03 AM
Last Post: elof
