How to modify *.conf files?
(07-08-2016, 11:47 AM)gbjensen Wrote:
(07-07-2016, 08:18 AM)xalius Wrote: You can always just plug the sdcard into your PC with a cardreader and edit the files there, no need for a rooted OS....
Hi xalius,
You might have a point, but after I have installed a EXT2 Volume manager and are able to see the content of my sd card, I can't find the root files.
Do you know where do I find the root files ? e.g /etc/audio_policy.conf ??
Many thanks for your help!
Hi, I found a better EXT2 manager, and can highly recommend Paragon ExtFS for windows.
With this tool I can mound my image at the PC and get access to all the files including the rooted files.
But anyway, modify the /etc/audio_policy.conf file (I changed from: "default_output_device AUDIO_DEVICE_OUT_SPEAKER" to: "default_output_device AUDIO_DEVICE_OUT_EARPIECE") did not had the expected effect.
How to modify *.conf files? - by gbjensen - 07-07-2016, 12:01 AM
RE: How to modify *.conf files? - by gbjensen - 07-07-2016, 12:57 AM
RE: How to modify *.conf files? - by Tarjei85 - 07-07-2016, 01:50 AM
RE: How to modify *.conf files? - by xalius - 07-07-2016, 08:18 AM
RE: How to modify *.conf files? - by gbjensen - 07-08-2016, 11:47 AM
RE: How to modify *.conf files? - by gbjensen - 07-09-2016, 01:05 AM
  How to modify IMEI Hoook 6 11,868 11-19-2019, 02:39 PM
  How to modify HOSTS file rvalecruz 1 3,329 02-02-2017, 12:53 AM
Last Post: MarkHaysHarris777
  Script for building DD image - I hate 18GB zip files! jonsmirl 1 2,746 07-28-2016, 07:10 PM
Last Post: xalius
