How to modify HOSTS file
I am trying to modify the "hosts" file so my Pine64 can be identified on my network with something other than "localhost".  However, when I bring up the file properties, there is no Change button to allow me to change the permissions.  Ideas?
(02-01-2017, 07:34 PM)rvalecruz Wrote: I am trying to modify the "hosts" file so my Pine64 can be identified on my network with something other than "localhost".  However, when I bring up the file properties, there is no Change button to allow me to change the permissions.  Ideas?
hi , the answer to your question can be complicated , and depends on your network setup;  whether you have a domain name server, and some other factors.  Basically, try the following in a terminal:
sudo -i
hostname  yournewname
( then use your editor of choice and edit  /etc/hosts )   I prefer vi, you might like nano or pluma:
vi  /etc/hosts
( leave the loopback alone:   127.0.0.1  localhost )
( add or change the line:  127.0.1.1  yournewname )
The other machines on your network need to be able to resolve yournewname to the machines ip address, and you do that by either 1) adding the machine to your domain name server, or 2) editing each machine's /etc/host file with a line matching the ip address and yournewname.
note: as you use your terminal and logon and logoff of sudo -i  you will get an error "unable to resolve name"  until you add the second loop line in  /etc/hosts   127.0.1.1  yournewname
note: obviously , for this to work your machine must have 1) either a static IP address, or 2) a reserved address issued by dhcpcd.
  How to modify IMEI Hoook 6 18,336 11-19-2019, 02:39 PM
  I can get Internet Connection, However I cannot download APK File (Kitkat and Lollipo deniyulianti 0 3,430 10-15-2016, 07:28 AM
Last Post: deniyulianti
  OTA file mikey0000 11 21,408 08-21-2016, 08:18 AM
  Access file systems nanoprobe 6 13,132 08-19-2016, 12:33 AM
Last Post: nanoprobe
  How to modify *.conf files? gbjensen 7 16,166 07-09-2016, 01:05 AM
Last Post: gbjensen
