Flashing gone wrong
(05-24-2022, 07:49 AM)wibble Wrote: You don't say which image you were trying to flash or which instructions you tried to follow. You should still be able to boot JumpDrive from the SD then reflash. If you look at the instructions carefully you'll see that they almost always say to dd to the raw device, not to a partition on it.
I flashed JumpDrive to the SD. Booted the phone, plugged into the laptop. I see two disks: /dev/sdd (sd card) and /dev/sdc with partitions /dev/sdc1 and /dev/sdc2
Now, if I try and do:
dd if=image.img of=/dev/sdc
I get: No space left on the device.
I try and peek with fdisk:
fdisk /dev/sdc
and there is one partition, size 10M, I also see this suspicious message:
GPT PMBR size mismatch (10854399 != 20479) will be corrected by write.
It doesn't get corrected by a write though. If I delete the partition within, save and exit and open it again, warning is still there.
fdisk /dev/sdc1
shows me two partitions:
Device       Start      End  Sectors  Size Type
/dev/sdc2p1  16384   266239   249856  122M EFI System
/dev/sdc2p2 266240 10852351 10586112    5G Linux filesystem
That's why I tried:
dd if=image.img of=/dev/sdc2
, because it looks like a separate drive to me. I guess I'm wrong?
I'm flashing it with arch with plasma
Flashing gone wrong - by erg - 05-24-2022, 07:15 AM
RE: Flashing gone wrong - by wibble - 05-24-2022, 07:49 AM
RE: Flashing gone wrong - by erg - 05-24-2022, 08:05 AM
RE: Flashing gone wrong - by fxc - 05-24-2022, 01:54 PM
RE: Flashing gone wrong - by erg - 05-24-2022, 02:53 PM
RE: Flashing gone wrong - by fxc - 05-26-2022, 05:30 AM
RE: Flashing gone wrong - by erg - 05-26-2022, 05:49 AM
RE: Flashing gone wrong - by mikehenson - 05-26-2022, 07:06 AM
RE: Flashing gone wrong - by erg - 05-26-2022, 07:18 AM
RE: Flashing gone wrong - by fxc - 05-28-2022, 10:52 AM
  SD Card has wrong capacity AndyM 11 2,641 06-11-2023, 12:30 AM
Last Post: AndyM
  trouble flashing eMMC TylerBlackberry 3 1,325 04-13-2023, 05:55 AM
  Boot problem: wrong screen orientation Jetpac 6 3,913 07-18-2022, 12:47 PM
Last Post: fravoi
  Wrong PIN error lordearl 3 4,357 09-20-2021, 03:19 AM
Last Post: mcdanielmark473
  After flashing UT on eMMC Convergence package not working anymore dfjdw8 0 1,583 06-11-2021, 12:28 AM
Last Post: dfjdw8
  Wrong language installed on PINE64 mobian edition Derek7 0 2,014 04-02-2021, 05:25 PM
Last Post: Derek7
  Trying to diagnose what's wrong... m16a1 6 5,662 02-24-2021, 08:45 PM
Last Post: C0ffeeFreak
  Flashing SC card for Ubuntu Touch thorensjubilee 2 3,609 12-15-2020, 07:38 AM
Last Post: thorensjubilee
  Flashing an SD card using Pinebook Pro? Konsole? SanjevR 5 5,098 12-08-2020, 02:58 PM
Last Post: hiimtye
  Wrong information in FAQ jbit 1 2,660 07-16-2020, 02:40 PM
Last Post: wibble
