Pinephone Pro won't boot
(04-18-2022, 03:05 AM)adosz Wrote:
(04-17-2022, 10:30 PM)Chief Wrote: Try press and hold the power button for about 30 seconds or until light comes on.
Unfortunately, that didn't work
Then try the same but first hold the volume button down as well. You may have to mess with procedure a bit.
Another option that I had to do once was remove battery, press the reset button and then power button and hold for several seconds.
Release buttons and then wait if possible till tomorrow and replace battery and then try normal start. Keep in mind the volume button as well.
If the phone does show sign of boot leave alone until fully booted up. Depending on os consider Manjaro Phosh. Good luck friend.
Also search on this site (What to do if your PinePhone Pro does not boot)
Pinephone Pro won't boot - by adosz - 04-17-2022, 11:06 AM
RE: Pinephone Pro won't boot - by Chief - 04-17-2022, 10:30 PM
RE: Pinephone Pro won't boot - by adosz - 04-18-2022, 03:05 AM
RE: Pinephone Pro won't boot - by Chief - 04-20-2022, 01:27 PM
RE: Pinephone Pro won't boot - by fxc - 04-23-2022, 02:39 AM
  PinePhone Pro EDL boot by shorting contacts ozkenlc 1 92 05-01-2024, 09:29 AM
Last Post: traut
Thumbs Up Pinephone Pro + Keyboard for sale Jimmy88 2 798 04-22-2024, 08:38 PM
Last Post: AegisWages
  PinePhone only turns on sometimes zvavybir 1 417 03-27-2024, 12:19 PM
Last Post: zvavybir
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 7 1,222 03-24-2024, 02:22 PM
Last Post: zetabeta
Question Screen turning off and booting problems with the Pinephone Pro xnZwJR6vys9a2wm7yWE4 0 233 01-16-2024, 02:38 PM
Last Post: xnZwJR6vys9a2wm7yWE4
  Pinephone Pro LCD and Touchscreen Hobgoblin 8 3,852 01-14-2024, 02:50 PM
Last Post: shifras
  Recurrent problems with broken charger chip on the pinephone/pinephone pro keyboard Jite 4 1,200 11-18-2023, 07:25 AM
Last Post: crocspot
  is it possible to install a pinephone pro mainboard in a pinephone hannescam 7 2,711 08-13-2023, 04:50 AM
Last Post: fxc
  Pinephone pro packet injection for internal wifi chipset covar 1 822 08-13-2023, 04:40 AM
Last Post: fxc
  PinePhone Keyboard won't work. read_kb_reg(PPKB_SYS_CONFIG) needs what? jovval 0 525 07-09-2023, 09:03 PM
Last Post: jovval
