Flashing with RF Connect
if you see pinecone, that's great, and that means you have the bootloader, and it's the latest one (1.0.0).
regarding changing InfiniTime version, i didn't catch it.
but in general, if you had e.g. version 1.8, and next installed OTA 1.9, and rebooted device,
the bootloader rolls back InfiniTime from 1.9 to 1.8, unless you clicked "verify" in the "Settings -> Firmware" screen.
it means, if you installed new InfiniTime update, and you are sure it works ok for you, you should verify that by clicking "verify" button.
in that way, during reboot, you stay with the validated version.
but if the new update doesn't work well, it's enough to reboot device (or it could be the device just "hung" and you have to wait for a battery drain), and after that, you should have the previously validated firmware. but there are catches you can read about here.
Away
Flashing with RF Connect - by ronaldheld - 04-11-2022, 03:53 AM
RE: Flashing with RF Connect - by ITCactus - 04-11-2022, 04:58 AM
RE: Flashing with RF Connect - by ronaldheld - 04-22-2022, 03:44 AM
RE: Flashing with RF Connect - by ITCactus - 04-22-2022, 03:55 AM
RE: Flashing with RF Connect - by ronaldheld - 04-26-2022, 06:49 AM
RE: Flashing with RF Connect - by wibble - 04-26-2022, 07:23 AM
RE: Flashing with RF Connect - by ITCactus - 04-26-2022, 08:19 AM
RE: Flashing with RF Connect - by ronaldheld - 04-27-2022, 04:02 AM
RE: Flashing with RF Connect - by ITCactus - 04-27-2022, 06:00 AM
RE: Flashing with RF Connect - by ronaldheld - 04-27-2022, 03:21 PM
RE: Flashing with RF Connect - by ITCactus - 04-28-2022, 03:25 AM
RE: Flashing with RF Connect - by ronaldheld - 04-28-2022, 03:56 AM
RE: Flashing with RF Connect - by ITCactus - 04-28-2022, 04:27 AM
  Connect to Google Fit on Android? Ccssid 0 428 12-24-2023, 09:06 AM
Last Post: Ccssid
  No Luck flashing WaspOS MadHatter 0 444 12-11-2023, 01:19 AM
Last Post: MadHatter
  Watchmate doesn't connect to PT anymore jojuma 1 1,436 02-07-2023, 02:43 AM
Last Post: azymohliad
  can anyone suggest their working Linux bluetooth USB dongles to connect to Pinetime? jahway603 4 2,745 07-27-2022, 07:38 PM
Last Post: jahway603
Question [question] how to restore PineTime to a factory state after flashing non-OTA/directly ITCactus 2 2,550 04-11-2022, 05:03 AM
Last Post: ITCactus
  Gadgetbridge vs RF Connect ronaldheld 2 2,485 03-30-2022, 06:14 AM
Last Post: danimations
Question Which companion apps work best for flashing firmware and pairing/syncing w/ Pinetime? danimations 0 1,550 03-28-2022, 08:22 PM
  PineTime re-connect to PInephone kmsgli 8 5,455 01-01-2022, 08:05 PM
Last Post: kmsgli
  BT WONT CONNECT mindwave 8 6,461 11-19-2021, 03:18 AM
Last Post: danielt
  After 0.7 -> 1.0 update cannot connect bluetooth piner67 2 3,121 06-21-2021, 01:39 PM
Last Post: piner67
