Gadgetbridge vs RF Connect
For an Android phone with pinetime running Infinitime, which app is better or preferred and why?
"nRF Connect" suits good only for Firmware update, and for developers.
for regular users on Android the "Gadgetbridge" is the only one of kind - it's the Companion app, and support a lot of feature (e.g. Firmware update, date/time sync, notifications sync, some steps sync).
for list of other Companion apps, see the "Companion apps" section here https://github.com/InfiniTimeOrg/InfiniT...anion-apps
Away
Gadgetbridge appears to be a good choice for pairing with an Android device. Worked for me for firmware updating, but I'm yet to try notification pushes.
Can someone tell me if Gadgetbridge can be run on the Pinephone via Anbox, or some other Android emulator?
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube Big Grin
  Issues Connecting with GadgetBridge XOmniverse 0 184 04-09-2024, 03:27 PM
Last Post: XOmniverse
  Connect to Google Fit on Android? Ccssid 0 392 12-24-2023, 09:06 AM
Last Post: Ccssid
  Watchmate doesn't connect to PT anymore jojuma 1 1,395 02-07-2023, 02:43 AM
Last Post: azymohliad
  can anyone suggest their working Linux bluetooth USB dongles to connect to Pinetime? jahway603 4 2,674 07-27-2022, 07:38 PM
Last Post: jahway603
  Flashing with RF Connect ronaldheld 12 7,234 04-28-2022, 04:27 AM
Last Post: ITCactus
  PineTime re-connect to PInephone kmsgli 8 5,316 01-01-2022, 08:05 PM
Last Post: kmsgli
  [SOLVED] Gadgetbridge not pairing with pinetime zoof 2 3,941 11-30-2021, 07:45 AM
Last Post: Schitzoflink
  BT WONT CONNECT mindwave 8 6,297 11-19-2021, 03:18 AM
Last Post: danielt
  Pinetime won't reconnect to gadgetbridge after being disconnected for a while kelbot 9 7,917 10-02-2021, 08:59 AM
Last Post: wilsonjw
  After 0.7 -> 1.0 update cannot connect bluetooth piner67 2 3,069 06-21-2021, 01:39 PM
Last Post: piner67
