Pinephone 64 Issues of a new user US Notheast as of April 2022
(04-10-2022, 07:52 PM)scrwbigtek Wrote:
(04-10-2022, 03:57 PM)fxc Wrote:
(04-10-2022, 02:34 PM)scrwbigtek Wrote: Fcx,
Ran the suggested "sudo pacman -Syu" command from Terminal.  It was on its way doing the updates, all looked fine, I set it down for a good while, came back later, screen would not show, phone was on, as plugging and unplugging power made the noises, but no display screen.
Forced a reboot, now stuck at the K of the KDE start up screen. Multiple reboots stuck at KDE "K" screen.  Basically now broken.
How do I reset the phone to default?
Sounds like the installation got corrupted. Make sure that updates don't get interrupted by the phone going into suspend. Recovering the phone is quite simple, on the regular PinePhone the microSD card has the highest boot priority, which means you can simply flash an operating system to the microSD and then insert it into the phone and boot from it.
If there is any further question or issue I strongly suggest you to join the bridged chat channels, as such questions are easily and quickly answered there by the community: https://wiki.pine64.org/wiki/Main_Page#Chat_Platforms
Thank you.
Just to close this. So had to roll up sleeves, but worth it.  Ended up formatting a microSD with Jumpdrive, grabbing the latest Manjaro Plasma Beta 11 for Pinephone release. The JumpDrive booted in the phone very well, Startup Disk Creator on my Desktop worked will with the Jumpdrive and attached phone, loaded up the image no problem.  Phone booted, did an update (said it did not take but it did). Manjaro Plasma 11 is WAY!!! smoother than the shipped software that came on the phone.  A ton more settings and with Simple Mobile here I selected T-Mobile -LTE fast.t-mobile.com for APN and it works well.  Calls, text, data.  This version of OS definitely in daily driver territory and will likely get a Pinephone Pro soon.  Take care.
Great. Be aware of the early software state of the PinePhone Pro. At the time of the writing currently not possible to daily-drive it.
RE: Pinephone 64 Issues of a new user US Notheast as of April 2022 - by fxc - 04-11-2022, 05:51 AM
  eSIM on PinePhone just_a_q 3 2,650 Yesterday, 03:41 PM
Last Post: bam
  Pinephone boot. Richy_T 4 146 05-06-2024, 08:32 AM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 926 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 459 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 310 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 111,302 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,969 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 697 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,628 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 565 12-26-2023, 02:42 PM
Last Post: shengchieh
