Distro for writers, k & m, LibreOffice, PostmarketOS?
Like USB, Bluetooth has standard device profiles. If manufacturers stick to the standard then the devices should 'Just Work' with linux. If they don't stick to the standard then someone has to do the reverse engineering work to find out exactly what they've done differently, then do the work to get a quirk to support this into the relevant upstream project (mostly kernel or bluez), or a separate one if the necessary bit is outside their scope. When a new standard version comes out it may take a while for support to be added - things like human interface devices using BLE spring to mind.
IIRC Logitech don't support linux - it's the other way round. They mostly stick to standards where applicable,so base functionality usually works reliably, and they are widely enough used that people have done the reverse engineering where needed for a lot of their products. Requests in their forum for a linux version of their Windows software get a polite "We've forwarded your request to our software team" but no action over many years.
RE: Distro for writers, k & m, LibreOffice, PostmarketOS? - by wibble - 06-17-2022, 01:39 AM
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 25,408 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Boxes at startup of LibreOffice cannot be executed Peter Gamma 0 776 06-12-2022, 03:02 AM
  Pinephone: Is there a frugal distro? orbital 2 2,045 05-27-2022, 09:34 PM
Last Post: orbital
  Bluetooth low energy & ANT+ sports sensors Pinephone distro? Peter Gamma 34 50,112 12-08-2021, 04:50 AM
Last Post: thibaultmol
  What distro should I try right now? dan640 1 2,669 02-14-2021, 06:35 AM
Last Post: evilbunny
  Low Battery indication (Manjaro/PostmarketOS with phosh) MamlinAV 3 4,523 12-16-2020, 03:44 AM
Last Post: dukla2000
  Can I use UT apps with another distro ? Sanexom 2 3,582 07-08-2020, 06:55 AM
Last Post: patrickjquinn
  After installing CRUST, what does a distro need to do to get wake on modem working? Subsentient 4 6,748 07-06-2020, 04:32 AM
Last Post: Alefnode
  Selecting a distro for a 32-bit application jfloren 3 5,124 02-04-2020, 02:03 PM
