03-23-2022, 09:03 AM
(03-19-2022, 09:00 AM)fxc Wrote:It is stated above that there is no sim card issue. There is no sim card slot issue until you have to use it, and use it, and use it. Then there is a sim card slot issue. Until the boot issues are fixed and you can just boot from eMMC and install a sd card (once) to use for extra storage, sim card slot issues will reappear here. In 6 or so years with an android phone, I put the sim card in once and an sd card in once and never touched them.(03-19-2022, 08:14 AM)ojimek Wrote: I'm also a pinephone user, using it as my main phone. I did buy a pinephone pro in january and got it in february. Less than a month after, it was dead. Not dead dead, but the sim card slot is broken, so now it's basically just an overpriced raspberry pi with a touchscreen.
I'm not the only one either, if you look at this forum, you'll find plenty of people mentioning having problems with the sim card slot, which is apparently a poor component. I haven't seen pine64 ackowledging it so far. So I wouldn't recommend to buy it for now, until the problem is acknowledged and fixed.
There is no SIM card slot issue. Occasionally people put empty SIM adapters in the slot or lose the SIM from the adapter (both cases user errors), in which case the contact pins can bent or break if the user applies brute force to remove the card again (second user error). The combined SIM card slot and microSD card reader is used since the original PinePhone and received a slight upgrade with the Pro, so I don't expect Pine64 folks to swap that component (and I doubt there are practical alternatives) to reduce user errors. Just be careful, don't apply force. I think that is common sense.
ojimek, please refrain from repeating accusations in further replies and wishing people a broken device, that kind of language is really unasked for. I would suggest you to have a look at the community rules.
I have a borked sim card slot in PPP due to repeated inserts/removals. I can't get pinephone company staff to even supply a part number to get a replacement after multiple emails. My PPP is on the shelf. Amazingly my PP is functioning well. It charges when you connect it through usb rather than discharging. It runs off of dedicated built-in memory. It doesn't automatically continually reboot when you are trying to charge it. Everything except MMS works to some extent. Even the camera. PP is using manjaro-phosh,beta23.
