Phone not reading sim
I got a micro sim, from the store, put it in, and restart the phone. The phone still says sim locked, and when I go into settings, it says no sim card installed. What should I do? UPDATE: It now says modem not available
(03-06-2022, 01:10 PM)For_lack_of_a_better_name Wrote: I got a micro sim, from the store, put it in, and restart the phone. The phone still says sim locked, and when I go into settings, it says no sim card installed. What should I do? UPDATE: It now says modem not available
what distro are you using?
Manjaro, the one that came preloaded.
This might seem like a stupid suggestion, but try flipping the modem dip switch off and then back on and then reboot.
I had the same issues when I was attempting to get my sim to be recognized. I was attempting to use the adapter that came with the phone. I switched to mobian and had the same issue. Long story short, I went to the verizon store, they got a new sim, popped the sim out (they kept sim) and gave me the piece that held the sim card. Put it in, instant success.
Hope that helped Smile
Received my Pinephone Pro today! Trying to get the SIM to recognize, just like in this thread, it reports "SIM locked", and then in settings, "no SIM detected". Now, I've been using this SIM in my everyday phone, where it lives in the smallest form factor. I tried popping it back into the adapter the SIM came in (a plastic card, nothing fancy) but it didn't help. Any ideas to what I might try? I have Mint Mobile, which is just less expensive T-Mobile, in case that matters. Thanks.
(03-30-2022, 01:17 PM)daveman1010220 Wrote: Received my Pinephone Pro today! Trying to get the SIM to recognize, just like in this thread, it reports "SIM locked", and then in settings, "no SIM detected". Now, I've been using this SIM in my everyday phone, where it lives in the smallest form factor. I tried popping it back into the adapter the SIM came in (a plastic card, nothing fancy) but it didn't help. Any ideas to what I might try? I have Mint Mobile, which is just less expensive T-Mobile, in case that matters. Thanks.
Hey, all. Figured I'd check in and see if anyone has a working SIM with the new Pinephone Pro. I get a message that says, "No WWAN Adapter Found" on latest updates from Manjaro Mobile. Not sure if I need to load a driver or something or if that's just a bad error message, but the sim doesn't work. Thanks.
Question Phone call with the pinephone pro dfs 5 4,287 02-10-2024, 09:54 PM
  PPP used with smart phone gaming fan. DaForest 3 864 11-19-2023, 05:17 AM
Last Post: crocspot
  Is the pine phone usable as a daily driver now? gautamb11 18 4,528 10-27-2023, 12:46 AM
Last Post: gregb49
  Pine Phone Pro: Mobian+plasma mobile GabrieleMax 2 1,569 04-30-2023, 05:03 AM
Last Post: diederik
  pine phone pro won't start robb777 2 1,404 01-25-2023, 04:38 PM
Last Post: emsyr
  Current State of PIne Phone Pro kmsgli 40 25,991 12-23-2022, 06:44 PM
Last Post: Simon Belmont
  Was the Pine Phone Pro you got from DHL new? theForce 3 2,045 10-31-2022, 04:26 PM
Last Post: fxc
  Internet is not working on Pine Pro phone caroljames972022 0 883 09-16-2022, 06:25 AM
Last Post: caroljames972022
  Loud echo on receiving phone when called TheRealThor 3 2,143 08-09-2022, 10:09 AM
Last Post: tckosvic
  New user. Very excited as this is my first linux phone...have a few questions 98cwitr 4 2,629 05-25-2022, 06:31 AM
Last Post: 98cwitr
