Armbian and LibreELEC and AltLinux for Quartz64
Added images from Gnome 3 for Quartz64. Surprisingly for me (I don't use gnome and built it at the user's request) the interface works well. Glmark2 shows on Quartz64-B
user@quartz64b:~$ glmark2
glmark2 2021.02
OpenGL Information
GL_VENDOR: Panfrost
GL_RENDERER: Mali-G52 r1 (Panfrost)
GL_VERSION: 3.1 Mesa 22.0.5
[build] use-vbo=false: FPS: 322 FrameTime: 3.106 ms
[build] use-vbo=true: FPS: 334 FrameTime: 2.994 ms
[texture] texture-filter=nearest: FPS: 569 FrameTime: 1.757 ms
[texture] texture-filter=linear: FPS: 566 FrameTime: 1.767 ms
[texture] texture-filter=mipmap: FPS: 572 FrameTime: 1.748 ms
[shading] shading=gouraud: FPS: 242 FrameTime: 4.132 ms
[shading] shading=blinn-phong-inf: FPS: 243 FrameTime: 4.115 ms
[shading] shading=phong: FPS: 236 FrameTime: 4.237 ms
[shading] shading=cel: FPS: 241 FrameTime: 4.149 ms
[bump] bump-render=high-poly: FPS: 97 FrameTime: 10.309 ms
[bump] bump-render=normals: FPS: 638 FrameTime: 1.567 ms
[bump] bump-render=height: FPS: 612 FrameTime: 1.634 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 438 FrameTime: 2.283 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 185 FrameTime: 5.405 ms
[pulsar] light=false:quads=5:texture=false: FPS: 543 FrameTime: 1.842 ms
[desktop] blur-radius=5:effect=blur:passes=1Confusedeparable=true:windows=4: FPS: 176 FrameTime: 5.682 ms
[desktop] effect=shadow:windows=4: FPS: 505 FrameTime: 1.980 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 83 FrameTime: 12.048 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 83 FrameTime: 12.048 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 72 FrameTime: 13.889 ms
[ideas] speed=duration: FPS: 229 FrameTime: 4.367 ms
[jellyfish] <default>: FPS: 274 FrameTime: 3.650 ms
[terrain] <default>: FPS: 24 FrameTime: 41.667 ms
[shadow] <default>: FPS: 160 FrameTime: 6.250 ms
[refract] <default>: FPS: 25 FrameTime: 40.000 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 426 FrameTime: 2.347 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 422 FrameTime: 2.370 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 425 FrameTime: 2.353 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 427 FrameTime: 2.342 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 418 FrameTime: 2.392 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 425 FrameTime: 2.353 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 303 FrameTime: 3.300 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 245 FrameTime: 4.082 ms
glmark2 Score: 320
RE: Armbian for Quartz64 - by shaggy013 - 03-15-2022, 01:56 PM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 03:48 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 04:58 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:11 AM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 07:21 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:25 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 02:31 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 05:19 AM
RE: Armbian for Quartz64 - by balbes150 - 03-21-2022, 01:28 AM
RE: Armbian for Quartz64 - by igorp - 03-23-2022, 04:14 AM
RE: Armbian for Quartz64 - by balbes150 - 04-01-2022, 07:36 AM
RE: Armbian and LibreELEC and AltLinux for Quartz64 - by balbes150 - 01-26-2023, 01:56 AM
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 0 233 03-27-2024, 12:53 PM
  DietPi OS for Quartz64 MichaIng 45 11,205 12-12-2023, 02:26 AM
Last Post: sickos
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 41,705 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 1,179 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 867 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 1,383 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 5,065 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 1,268 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 27,022 03-17-2022, 06:29 AM
Last Post: balbes150
