Armbian and LibreELEC and AltLinux for Quartz64
#93
(12-07-2022, 04:14 PM)bosi564 Wrote:
(12-07-2022, 12:49 AM)balbes150 Wrote: @bosi564  I wrote to you about checking the launch of a "clean" Armbian without EDK2. That is, you need to download and burn an image from the directory to the SD card WITHOUT specifying "EDK-EFI" in the directory name. Check the launch of the EDGE and CURRENT versions. And show the UART log when launching the EDGE and CURRENT versions.
For the files:
1. 20221101-current/Armbian_22.11.0-trunk_Quartz64a_jammy_current_5.19.17.img.xz
2. 20221112-edge/Armbian_22.11.0-trunk_Quartz64a_jammy_edge_6.1.0.img.xz
I've downloaded both files. Had to change baud rate to 115200 and 9800 for 1. and 2., otherwise the output on the serial console was all unreadable. Both times the boot didn't reach login shell.
I've attached the logs.
EDIT: seems like the the first log file kernel-5-current-115200baud.log contains logs for kernel version 6.1.0-rc4-media. I'll redo the test and post the log again.
EDIT 2 : I've removed the wrong log file and uploaded the log file 'kernel-5-current-115200.log' for the correct image.
Very strange, by default all RK use 1500000 (in the kernel and u-boot), if you set the wrong values, the output does not work. Judging by the log files, there is no useful data there. How and where is your UART console connected ? Which USB-TTL chip do you use? Have you tried changing the contents of SPI before ? What other Linux versions have you checked before, what does the UART console show with them?
RE: Armbian for Quartz64 - by shaggy013 - 03-15-2022, 01:56 PM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 03:48 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 04:58 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:11 AM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 07:21 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:25 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 02:31 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 05:19 AM
RE: Armbian for Quartz64 - by balbes150 - 03-21-2022, 01:28 AM
RE: Armbian for Quartz64 - by igorp - 03-23-2022, 04:14 AM
RE: Armbian for Quartz64 - by balbes150 - 04-01-2022, 07:36 AM
RE: Armbian and LibreELEC and AltLinux for Quartz64 - by balbes150 - 12-07-2022, 11:41 PM
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 0 232 03-27-2024, 12:53 PM
  DietPi OS for Quartz64 MichaIng 45 11,187 12-12-2023, 02:26 AM
Last Post: sickos
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 41,686 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 1,178 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 863 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 1,383 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 5,061 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 1,264 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 27,008 03-17-2022, 06:29 AM
Last Post: balbes150
