Armbian and LibreELEC and AltLinux for Quartz64
#83
Quote:.I found in the source code and in the release tags that there were two versions with 4GB and 8GB for Quartz64 in the beginning. Try the options from the website for the 8GB version.
If this works, I'll try adding another option for the 8GB version.
https://github.com/jaredmcneill/quartz64_uefi/releases
I tried both the latest release from the link and the one which is a bit older, but for the 8GB ram variant and both didn't work out. Before that I've zeroed the microSD one time for the unified image (which tests for ram) and forgot to zeroed it before writing the older image for 8gb, but I think the Tianocore EDK image works fine. For example your image does recognize (from the tianocore menu) that the board has 8 gigabytes of ram and that the CPU is running at a speed close to 2ghz.
Also I tried armbian 23 from the community releases:
1. Armbian_23.02.0-trunk_Quartz64a_kinetic_edge_6.0.11.img
2. Armbian_23.02.0-trunk_Quartz64a_kinetic_edge_6.0.11_xfce_desktop.img
But the same problem occurred - the system didn't boot successfully.
I did try to randomly remove from the kernel's command line a "ro", which preceded a "rw" and some fsck.* options which resulted in that the monitor didn't go to sleep, although it didn't boot either.
Quote:Ver 20221204-EDK-EFI with support for direct launch from SD card, USB recording is not needed.
I had written a question earlier, but forgot to publish it. Where can I download this version? I couldn't find it at recent links.
RE: Armbian for Quartz64 - by shaggy013 - 03-15-2022, 01:56 PM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 03:48 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 04:58 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:11 AM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 07:21 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:25 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 02:31 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 05:19 AM
RE: Armbian for Quartz64 - by balbes150 - 03-21-2022, 01:28 AM
RE: Armbian for Quartz64 - by igorp - 03-23-2022, 04:14 AM
RE: Armbian for Quartz64 - by balbes150 - 04-01-2022, 07:36 AM
RE: Armbian and LibreELEC and AltLinux for Quartz64 - by bosi564 - 12-05-2022, 05:19 PM
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 0 236 03-27-2024, 12:53 PM
  DietPi OS for Quartz64 MichaIng 45 11,213 12-12-2023, 02:26 AM
Last Post: sickos
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 41,707 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 1,182 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 873 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 1,386 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 5,067 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 1,268 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 27,022 03-17-2022, 06:29 AM
Last Post: balbes150
