Armbian and LibreELEC and AltLinux for Quartz64
#70
(09-07-2022, 02:33 AM)digitaldaz Wrote: @balbes150  Excellent work as ever, thank you.
root@quartz64a:~# uname -a
Linux quartz64a 5.19.7-station-p2 #trunk SMP PREEMPT Mon Sep 5 13:11:27 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
root@quartz64a:~# cat /etc/issue
Armbian 22.11.0-trunk Jammy \l
I cannot upload a dtb so here it is: https://www.t95plus.com/forums/downloads...tz-cm4.dtb
This is the only image I've found that can boot from sd. Can you share your sources so I can modify/compile it?  Going on a month of just trying to boot a soquartz from sd here.
Your image linked on the soquartz wiki references quartz-64-a.dtb though it boot nicely via sd on a model a base board and a pi cm4 io board fwiw! Good work to the both of you ( and @balbes150 of course ) and thank you.
RE: Armbian for Quartz64 - by shaggy013 - 03-15-2022, 01:56 PM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 03:48 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 04:58 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:11 AM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 07:21 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:25 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 02:31 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 05:19 AM
RE: Armbian for Quartz64 - by balbes150 - 03-21-2022, 01:28 AM
RE: Armbian for Quartz64 - by igorp - 03-23-2022, 04:14 AM
RE: Armbian for Quartz64 - by balbes150 - 04-01-2022, 07:36 AM
RE: Armbian and LibreELEC and AltLinux for Quartz64 - by kbanfield - 11-06-2022, 01:04 PM
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 0 237 03-27-2024, 12:53 PM
  DietPi OS for Quartz64 MichaIng 45 11,233 12-12-2023, 02:26 AM
Last Post: sickos
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 41,722 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 1,187 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 874 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 1,386 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 5,070 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 1,268 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 27,025 03-17-2022, 06:29 AM
Last Post: balbes150
