Armbian and LibreELEC and AltLinux for Quartz64
(03-16-2022, 07:25 AM)shaggy013 Wrote: yeah i cant find the attach button
https://drive.google.com/file/d/18Qr1wrO...sp=sharing
here is the bootlog
Yes, I see such messages in the log (not only for Quartz64, but also on other RK models), I think this may be a problem of the initial stage of development, not all modes (models) of the SD card are supported yet. More often I see this on old (slow) SD cards.
Updating images 20220317 (edge 5.17 and current 5.16).
The operation of the standard procedure for installing the system on eMMC via armbian-config has been verified (i.e. you can install the system on eMMC directly on the Quartz64 itself, no additional adapter is needed to write the eMMC module via USB).
Added support for starting the system from USB media. This greatly simplifies and expands the possibilities of running different systems (for example, during testing). Now you can use not only SD cards, but also any USB media to start (and/or work). For example, I installed and configured the Armbian working system on eMMC (with support for launching from USB) and now I easily launch other Armbian test images from ordinary USB flash drives, which is much easier to handle (no card readers are needed to write SD cards, the cost of USB flash drives is much lower and the choice of which models to use \ buy is much wider).
The operation of HDMI sound and analog sound has been tested.
Since I have no way to check NVMe (there is no Pine64 adapter to install NVMe in PCIe), please ask those who have such adapters to check whether NVMe is detected or not.
RE: Armbian for Quartz64 - by shaggy013 - 03-15-2022, 01:56 PM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 03:48 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 04:58 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:11 AM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 07:21 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:25 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 02:31 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 05:19 AM
RE: Armbian for Quartz64 - by balbes150 - 03-21-2022, 01:28 AM
RE: Armbian for Quartz64 - by igorp - 03-23-2022, 04:14 AM
RE: Armbian for Quartz64 - by balbes150 - 04-01-2022, 07:36 AM
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 0 191 03-27-2024, 12:53 PM
  DietPi OS for Quartz64 MichaIng 45 10,844 12-12-2023, 02:26 AM
Last Post: sickos
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 41,258 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 1,127 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 828 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 1,332 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 4,986 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 1,246 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 26,557 03-17-2022, 06:29 AM
Last Post: balbes150
