Armbian and LibreELEC and AltLinux for Quartz64
Extreme long boot time
login setup is annoying Level could be bit lower , can't even use thc013 as username
no graphical desktop debian and hirsute
uboot from android on emmc (like firefly uboot) doesnt like the sd it panics
the errors are
ITS queue timeout (128 65)
ITS cmd its_build_invall_cmd failed
panfrost fde60000.gpu: get clock failed -517
panfrost fde60000.gpu: clk init failed -517
Bluetooth: hci0: command 0x0c03 tx timeout
Bluetooth: hci0: BCM: Reset failed (-110)
ow and your uboot is set at 1560 Wink .
well that is for the images didnt build "build" yet
current wants to build 5.10 ?
bad defconfig Smile not many have a dvdsky pcie card for testing pcie
0426-MALI-bifrost-resolve-error-when-make-clean.patch
0434-MALI-bifrost-fix-compilation-errors-when-CONFIG_DEBU.patch
0471-MALI-bifrost-fix-an-error-in-Kbuild.patch
thought those were the patches i reverted to get hdmi/graphics working on the 5.10 from 01-18 (wich has a fix for vop grf) Wink for a rk356x board
another brand has a newer 5.10 on their git Wink but i didnt build that kernel yet
ow and for 4.19 you could just throw the 2 mali update patches from 5.10
ah i see
your on 5.14 , 5.17 is more stable i think
i would follow the original dts without the ebc setting more.
pgwipeout gives it a lot of attention .
and i saw that earlier you are patching the hdmi and change the setting from a to c , i cannot follow that or i dont see why .
./compile.sh EXPERT=yes CREATE_PATCHES=yes WIREGUARD=no EXTRA_WIFI=no
might take a look at warpme minimyth2 repo he also has a multiboard kernel
RE: Armbian for Quartz64 - by shaggy013 - 03-15-2022, 01:56 PM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 03:48 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 04:58 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:11 AM
RE: Armbian for Quartz64 - by balbes150 - 03-16-2022, 07:21 AM
RE: Armbian for Quartz64 - by shaggy013 - 03-16-2022, 07:25 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 02:31 AM
RE: Armbian for Quartz64 - by balbes150 - 03-17-2022, 05:19 AM
RE: Armbian for Quartz64 - by balbes150 - 03-21-2022, 01:28 AM
RE: Armbian for Quartz64 - by igorp - 03-23-2022, 04:14 AM
RE: Armbian for Quartz64 - by balbes150 - 04-01-2022, 07:36 AM
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 0 214 03-27-2024, 12:53 PM
  DietPi OS for Quartz64 MichaIng 45 10,939 12-12-2023, 02:26 AM
Last Post: sickos
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 41,345 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 1,142 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 839 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 1,339 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 5,012 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 1,248 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 26,836 03-17-2022, 06:29 AM
Last Post: balbes150
