Has anyone switched to the userspace keyboard driver on Manjaro ARM?
(03-10-2022, 11:34 AM)Hook Wrote: I admit to being a noob.  I am pretty good at researching before asking a question, and I follow directions well, but I am limited in my ability to troubleshoot on my own.
Has anyone on Manjaro (Phosh, but that shouldn't matter) switched to the userspace driver (ppkb-i2c) for the keyboard case?  If so, can you post how you did it?
I was hoping maybe I could just use the instructions for Arch starting at step 3:
https://forum.pine64.org/showthread.php?tid=16156
Unfortunately, I can't even get out the  gate because Manjaro Arm does  not seem to have a mkscr command (The boot.txt file says at the top to run "pp-uboot-mkscr" but that fails to with a "command not found" message. and there is no ".scr" file with a similar name on the boot directory).  There is a boot.scr file in the boot directory, and, yes, I am in that directory when issuing the commands.
Any help from someone using Manjaro Arm would be appreciated.
TIA
Does the file:
/boot/mkscr
exist?  It should be with the files '/boot/boot.txt' and '/boot/boot.scr'
And is it executable (-rwxr-xr-x) ?
to list the files and their permissions in the '/boot' directory:
cd /boot
ls -l
If it doesn't exist, manually create it:
sudo nano /boot/mkscr
RE: Has anyone switched to the userspace keyboard driver on Manjaro ARM? - by Ephraimbogan - 08-16-2023, 03:16 AM
  keyboard case charging but not typing new2pinephone 18 5,873 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 9,246 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 437 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,219 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 460 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,255 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 528 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 624 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,035 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 846 10-11-2023, 09:03 AM
Last Post: elof
