Has anyone switched to the userspace keyboard driver on Manjaro ARM?
(05-03-2023, 07:36 AM)Hook Wrote:
(05-03-2023, 06:46 AM)undata Wrote:
(03-25-2022, 12:32 PM)Hook Wrote: Okay, here is what finally worked for me.  I started with MajaroArm with all updates.  I also installed from the software app (Phosh) pinephone-keyboard-git and pinephone-toolkit-git, which may have helped.  I did not have to do any building of the userland driver, so an update may have already provided it, or maybe one of the git files I mentioned. Whatever, it already existed at the proper location when I started this.
Here are all of the exact steps I took:
1. Create systemd file
  a. Navigate  to /etc/systemd/system
  b. sudo nano keeb2.service (use whatever name you like before the ".service")
  c.In file, type:
  [Unit]
  Description=PinePhone keyboard userspace daemon
  [Service]
  Type=simple
  ExecStart=/usr/bin/ppkb-i2c-inputd
  [Install]
  WantedBy=multi-user.target
d. Save and exit Nano
2. Enable service for next boot
  a. Run: sudo systemctl enable keeb2.service
3. Set up boot.txt file to disable kb151
  a. cd /boot
  b. sudo nano boot.txt
  c. Type kb151.disable_input at the end of setenev bootargs line (there should be one space between last parameter in the line and this addition).
  d. save and close.
4. Create the new boot.scr from the boot.txt file to apply disabling kb151 at next boot.
  a. Run: /usr/bin/pp-uboot-mkscr
5. Reboot
This worked for me with MajaroArm. I have F1-F10 working with the pine key, and Fn-num keys actually type what is printed on the lower part of the keys.
I potched this together from different sources, (the link in the first post and the very helpful comments in this thread) and a lot of exploring to see where files were actually located and if I had them.  Many thanks to @Megamemnon and @neil_swan80, as well as another not on this forum.  And, of course, thanks to the ManjaroArm devs.
Hope this helps someone else.
It didn't work for me. No offense, but you started out saying "I did not have to do any building of the userland driver, so an update may have already provided it, or maybe one of the git files I mentioned." You followed that by saying "Here are all of the exact steps I took:" How is it possible that those were ALL of the exact steps as listed, if you weren't sure whether previous steps had any impact?
Okay. Well, nearly a year later, as you probably can tell if you read the whole thread, it kept breaking, so not all that surprising it didn't work for you. I gave up.  I no longer have a Pinephone  or keyboard case, so it's all kind of moot.  Lol.
You're right. Still, I have solved this frustrating problem. Using only gsettings. I will share my work, if anybody cares about the details. I just bought the keyboard in 2023. Had I known the problem I wouldn't have bought it. But after a lot of extremely tedious work, here it is (link to photographic evidence):
https://drive.google.com/file/d/12wBDZ9M...sp=sharing
RE: Has anyone switched to the userspace keyboard driver on Manjaro ARM? - by undata - 05-11-2023, 01:28 PM
  keyboard case charging but not typing new2pinephone 18 6,075 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 11,398 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 462 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,327 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 483 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,314 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 554 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 655 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,079 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 892 10-11-2023, 09:03 AM
Last Post: elof
