sudo NOPASSWD not working
If you added the line to /etc/sudoers be sure that you placed it at the end of the file not at the beginning.  I *think* it should go after the line which says @includedir /etc/sudoers.d.  The reason for this is that the file is processed sequentially which means that something later in the file could override your change.
Additionally, I *think* the syntax you've used is for groups not individual users.  Try
user ALL=(ALL) NOPASSWD: ALL
Also, be sure to edit the /etc/sudoers file using only visudo.  Funky things can/will happen if you use something else.
Caveat: I try really really hard to never leave such a huge yawning security opening as this, so I haven't tried any of the above.  I.e., ymmv.  Hopefully something here is helpful for you, though.
Ulp...my reply got lost.  Here's what I can remember of it.
Do your editing at the very end of /etc/sudoers.  I think you want to put it after the line that includes stuff from sudoers.d.  The reason for that is because the file is processed sequentially so if you do stuff at the beginning of that file it *could* get overridden by lines later in the file or in the included file(s).
Only use visudo to edit /etc/sudoers.  Funky stuff can/will happen if you use some other editor.
Your syntax might be wrong.  I think your syntax is for a group not an individual user.  Try this
Obligatory warnings...I wouldn't do this because it leaves a huge security opening.  So I haven't tried any of the above.  Consequentially ymmv.
I hope something here is helpful for you.
rz
sudo NOPASSWD not working - by Greendrake - 03-05-2022, 05:41 AM
RE: sudo NOPASSWD not working - by arzach - 03-05-2022, 02:57 PM
RE: sudo NOPASSWD not working - by packmule43 - 03-05-2022, 03:39 PM
RE: sudo NOPASSWD not working - by Greendrake - 03-05-2022, 05:24 PM
RE: sudo NOPASSWD not working - by arzach - 03-05-2022, 09:02 PM
RE: sudo NOPASSWD not working - by Fred Zyphal - 03-06-2022, 11:47 AM
RE: sudo NOPASSWD not working - by arzach - 03-06-2022, 08:51 PM
  Back/World camera working after suspend DrYak 2 960 11-14-2023, 09:44 AM
Last Post: DrYak
  Netfilter not working on latest manjaro kernel robocone 1 1,235 12-29-2022, 09:11 PM
Last Post: robocone
  Monjaro Plasma Cell Network and Data not working properly maiyuzhe 2 1,631 09-24-2022, 12:15 AM
Last Post: maiyuzhe
  Manjaro 5.17.5-1 Keyboard stopped working Yst 7 4,047 06-09-2022, 11:12 AM
Last Post: graphicpanda444
  Plasma Mobile navigation bar scaling is not working Yst 0 857 05-09-2022, 05:10 AM
Last Post: Yst
  Convergence Working on PPP? joshndroid 3 2,526 04-27-2022, 01:30 PM
Last Post: TheBlindEarthican
  tow-boot: suspend stopped working maltee 3 2,276 03-30-2022, 10:43 AM
Last Post: brb78
  Keyboard stopped working -- big problem tckosvic 15 7,680 02-06-2022, 02:04 PM
Last Post: Emilio
  Guide: Recovering from not being able to boot to eMMC or working sdcard Ulfnic 2 2,606 02-02-2022, 10:29 PM
Last Post: bcnaz
