Needed -- list of PPP hardware button combinations
When you boot your computer and it tells you to hold F12 to start the BIOS, how many keys do you need to hold to access the BIOS? The answer is 1, the F12 key. If you press it too late, you will end in Ubuntu. If Ubuntu is running, your PC won't start the BIOS when you press F12. If power is not plugged in, your BIOS won't start. If your PC is stuck in GRUB and you have no display output and you press F12, the BIOS won't load either.
To boot the microSD card on the PinePhone Pro, you need to hold the RE key at boot.
RE: Needed -- list of PPP hardware button combinations - by fxc - 03-04-2022, 12:23 PM
  Anyone else having CPU hardware issues? 98cwitr 2 122 05-10-2024, 01:27 PM
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 838 02-17-2024, 04:04 AM
Last Post: fxc
  Pinephone Pro does not start with RE button pressed c0ssan 10 5,629 09-28-2023, 09:21 AM
Last Post: R0bbi3Mack
Question Where do i check/post/report bugs/issues with the software? (or hardware?) nande 4 2,681 04-02-2022, 10:31 AM
Last Post: wibble
  Needed -- Clarification of Boot SequenceInstructions tckosvic 3 2,253 03-04-2022, 06:20 PM
Last Post: fxc
  Sudo rm /var/lib/pacman/db.lck -- keeps being needed tckosvic 2 1,979 02-09-2022, 12:03 PM
Last Post: tckosvic
  Pinephone Pro hardware revision in the works? Gooberpatrol66 1 1,595 01-19-2022, 12:39 AM
Last Post: bcnaz
