BUILD CUSTOM SDK
(03-07-2022, 04:59 PM)dieselnutjob Wrote: Have I understood correctly that with your 4.19 the MIPI-DSI LCD panel will work, but with your 5.10 it won't ?
I understand why everyone says just to use mainline, but for an LCD panel it doesn't yet work (though I think that they are getting near).
it is just a rk 4.19 nothing realy special maybey a few versions higher as on your original tablet firmware
you know it all comes to the dts i disabled dsi-mipi in my dts because i dont use it .
for now you could be a little more lucky with a downstream kernel like this kernel for your tablet to get display output .
just look what changed in the dts files of your dtb with recent dts files also dts files change a litte with build verions 4.19.219 has little changes from example .193
thought mipi0 got video0 but you will find out
the 5.10 you just forget
do you have a dtb or dts of your tablet i can throw it in a android 12 build Smile
BUILD CUSTOM SDK - by shaggy013 - 02-14-2022, 05:29 PM
RE: BUILD CUSTOM SDK - by fasani - 02-24-2022, 07:17 AM
RE: BUILD CUSTOM SDK - by shaggy013 - 02-24-2022, 08:53 AM
RE: BUILD CUSTOM SDK - by tllim - 02-27-2022, 04:12 PM
RE: BUILD CUSTOM SDK - by shaggy013 - 02-28-2022, 06:33 AM
RE: BUILD CUSTOM SDK - by shaggy013 - 03-02-2022, 03:04 AM
RE: BUILD CUSTOM SDK - by x893 - 03-05-2022, 12:06 AM
RE: BUILD CUSTOM SDK - by shaggy013 - 03-07-2022, 09:57 AM
RE: BUILD CUSTOM SDK - by x893 - 03-07-2022, 12:34 PM
RE: BUILD CUSTOM SDK - by shaggy013 - 03-10-2022, 05:58 AM
RE: BUILD CUSTOM SDK - by dieselnutjob - 03-07-2022, 04:59 PM
RE: BUILD CUSTOM SDK - by shaggy013 - 03-08-2022, 01:43 PM
RE: BUILD CUSTOM SDK - by shaggy013 - 03-09-2022, 05:09 PM
RE: BUILD CUSTOM SDK - by x893 - 03-10-2022, 03:44 AM
RE: BUILD CUSTOM SDK - by shaggy013 - 03-11-2022, 01:02 PM
RE: BUILD CUSTOM SDK - by Randomuser - 07-15-2022, 04:40 PM
RE: BUILD CUSTOM SDK - by dieselnutjob - 03-10-2022, 09:41 AM
RE: BUILD CUSTOM SDK - by shaggy013 - 03-10-2022, 12:13 PM
RE: BUILD CUSTOM SDK - by x893 - 03-10-2022, 04:01 PM
RE: BUILD CUSTOM SDK - by shaggy013 - 03-11-2022, 07:14 AM
RE: BUILD CUSTOM SDK - by Randomuser - 07-17-2022, 10:49 AM
RE: BUILD CUSTOM SDK - by shaggy013 - 07-17-2022, 11:00 AM
RE: BUILD CUSTOM SDK - by Randomuser - 07-18-2022, 10:30 AM
RE: BUILD CUSTOM SDK - by shaggy013 - 07-18-2022, 11:55 AM
RE: BUILD CUSTOM SDK - by Randomuser - 07-18-2022, 10:11 PM
RE: BUILD CUSTOM SDK - by shaggy013 - 07-20-2022, 07:37 AM
RE: BUILD CUSTOM SDK - by shaggy013 - 12-03-2022, 04:33 AM
RE: BUILD CUSTOM SDK - by shaggy013 - 12-05-2022, 01:05 PM
  SOQuartz Getting a working build dl-m10 7 3,750 01-23-2023, 06:38 PM
Last Post: diederik
  PCIe not working on custom board (soquartz) dferrg 1 2,016 02-23-2022, 04:31 AM
Last Post: dferrg
  Debian Userland on top of existing Linux build? dieselnutjob 3 3,385 01-25-2022, 01:12 PM
Last Post: dieselnutjob
