SOQuartz Getting a working build
I recently started evaluating the SOQuartz to use as a replacement for the Pi CM4 but am struggling to get any working version of linux. I was able to run the debian installer from this but after completing set up I get this read out bellow:
U-Boot SPL board init
U-Boot SPL 2017.09-ga1f6fc00a0-210413 #ldq (Apr 13 2021 - 11:35:00)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
No misc partition
spl: partition error
Trying to boot from MMC1
MMC error: The cmd index is 0, ret is -110
mmc_init: -110, time 5
spl: mmc init failed with error: -110
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
# Reset the board to bootrom #
Has anyone gotten their SOQuartz to work?
Use this, this should help you, it will boot off emmc or sd card: https://www.t95plus.com/forums/downloads...-io.img.gz
I made this from various other sources to work with the super6c carrier board. Its running well, I have a four node ceph cluster running with nvme.
See this thread for a little more info. https://github.com/adamfowleruk/deskpi-super6c/issues/2
SSH in, username root, password 1234.
Armbian Ubuntu Jammy with kernel 5.19.7
https://www.t95plus.com/forums/downloads...9.7.img.gz
A better image, IMHO that the one I shared above. This is a regular Balbes150 image for the Quartz A but with a working uboot and a changed DTB.
Burn the image to SD/EMMC
Boot up you module, give it a couple of minutes to resize sdcard/emmc and then find its IP
Log in via SSH root/1234 and it will take you through the armbian first boot process.
Just to clarify something: This is NOT regarding the "Model A Base board" they sell for the Soquartz, right?
https://pine64.com/product/soquartz-model-a-baseboard/ <-- this is the one I purchased.
Whereas you guys are using the Raspberry Pi CM4 IO Board, correct?
(09-07-2022, 06:53 AM)digitaldaz Wrote: Armbian Ubuntu Jammy with kernel 5.19.7
Can you tell me how to modify the dtb for this?
(10-14-2022, 10:47 AM)kbanfield Wrote: Just to clarify something: This is NOT regarding the "Model A Base board" they sell for the Soquartz, right?
Armbian for SOQuartz + SOQuartz Model-A Baseboard
https://forum.pine64.org/showthread.php?...#pid115529
I have used it in the Pi baseboard: https://www.waveshare.com/wiki/CM4-IO-BASE-A
Also, https://deskpi.com/collections/deskpi-su...-supported
I currently have mine now in the soquartz blade: https://pine64.com/product/soquartz-blade/
The blade is excellent, includes POE.
NVME works on all of them.
It should (also) work with Plebian GNU/Linux (Debian Bookworm). See https://forum.pine64.org/showthread.php?tid=17779 for more
  How force HDMI out in soquartz rahmanshaber 0 287 11-15-2023, 03:51 PM
Last Post: rahmanshaber
  SOQuartz Linux Builds stormwyrm 1 443 11-13-2023, 02:53 AM
Last Post: diederik
  SOQuartz Blade PXE Boot NCLI 1 809 05-05-2023, 09:49 AM
Last Post: CounterPillow
  BUILD CUSTOM SDK shaggy013 27 24,208 12-05-2022, 01:05 PM
Last Post: shaggy013
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 1,230 07-21-2022, 01:08 PM
Last Post: Randomuser
  Using soquartz's MIPI DSI1 output axelm 1 2,167 05-28-2022, 07:48 AM
  PCIe not working on custom board (soquartz) dferrg 1 2,003 02-23-2022, 04:31 AM
Last Post: dferrg
  Debian Userland on top of existing Linux build? dieselnutjob 3 3,348 01-25-2022, 01:12 PM
Last Post: dieselnutjob
