Wireless charger (QI) not working on PinePhone Pro
(04-19-2022, 08:58 AM)ertizpau Wrote:
(04-09-2022, 07:30 PM)kmsgli Wrote: I have the same issue, just received my pro and swapped the back off my original pine phone and Qi charging not working.
I notice the pogo pins appear a few mm's shorter on the pro than the original pinephone. Could they not be reaching the back cover and not making a connection?
Good point. I cannot make pins longer but I can move "back cover" closer. I have put soft isolation tape between back cover and tape with connectors. Now pins are reaching it and wireless charging is working. however charging speed is poor. I will have to play with this hack more.
If that works then what pine64 has told me that the cpu draws to much power and the Qi charger cant supply is not correct. This seems like it could be fixed with a small adapter plate maybe I will start working on something as well. Keep me posted on what you come up with.
RE: Wireless charger (QI) not working on PinePhone Pro - by kmsgli - 04-19-2022, 02:55 PM
  Keyboard not working PPP is support broken atm? joshndroid 13 3,450 02-24-2024, 01:59 PM
Last Post: mburns
  The XIT bluetooth folding keyboard can work with the Pinephone Pro mburns 0 293 11-09-2023, 10:57 AM
Last Post: mburns
  Pinephone Pro battery case deedend 2 763 09-25-2023, 06:05 PM
Last Post: deedend
  Fixing the PinePhone Keyboard for the Linux Console mburns 0 513 09-02-2023, 07:48 AM
Last Post: mburns
  Compatible replacement battery for the Pinephone Pro tpoacher 3 3,913 06-01-2023, 06:51 PM
Last Post: dchang0
  Getting Started with the PinePhone Pro Accessories fxc 0 3,831 04-10-2022, 06:36 AM
Last Post: fxc
  Is the dock for Pinephone compatible with the Pinephone pro? Viengi28 1 1,732 04-08-2022, 10:30 AM
Last Post: pearingron
