Is the dock for Pinephone compatible with the Pinephone pro?
https://pine64.com/product/pinephone-usb-c-docking-bar/
It's really important that its possible to connect it to a monitor and keyboard. I guess there shouldn't be a problem but haven't seen it documented and the pro doesn't come with any accessories so just wanted to make sure.
Monitor output is still at large. The USB-C docking bar that came with my OG convergence model usually works with the Pro aside from that. Also noticed that it disconnects very easily if you have the keyboard case on.
  The XIT bluetooth folding keyboard can work with the Pinephone Pro mburns 0 1,935 11-09-2023, 10:57 AM
Last Post: mburns
  Pinephone Pro battery case deedend 2 3,775 09-25-2023, 06:05 PM
Last Post: deedend
  Fixing the PinePhone Keyboard for the Linux Console mburns 0 2,166 09-02-2023, 07:48 AM
Last Post: mburns
  Compatible replacement battery for the Pinephone Pro tpoacher 3 10,425 06-01-2023, 06:51 PM
Last Post: dchang0
  A dock/hub that works with PPP (for ur information) miaoish 1 3,926 03-26-2023, 03:59 AM
Last Post: miaoish
  Power pass through USB-C dock that works? (HDMI out and charges phone) jcun4128 8 11,222 01-15-2023, 08:41 PM
Last Post: fox95
Exclamation Wireless charger (QI) not working on PinePhone Pro zeroskyx 6 11,331 05-13-2022, 09:59 AM
Last Post: zeroskyx
  Getting Started with the PinePhone Pro Accessories fxc 0 8,804 04-10-2022, 06:36 AM
Last Post: fxc
