SD Card insertion depth
(02-02-2022, 08:02 AM)bcnaz Wrote: I always just push it in until it bottoms in the socket...  (and straight)
  I opened one of my phones and compared it to your photo,  yep,  that is how it looks.
I have never had a problem with the socket,  ---->  I have swapped sd cards hundreds of times since the old Brave Heart days.
Thank you everyone for the responses.  I was concerned that I was either pushing the card in too far or had damaged the slot somehow.  As it turns out, I took the suggestion in another thread to try using Etcher to write the image to the sd card which indicated a verification problem after the write was done.
I switched to another SD card which worked beautifully... I was able to boot successfully into Mobian after holding the power button down for 5 seconds.
SD Card insertion depth - by nristen - 02-01-2022, 12:02 PM
RE: SD Card insertion depth - by dukla2000 - 02-01-2022, 03:23 PM
RE: SD Card insertion depth - by tckosvic - 02-01-2022, 06:54 PM
RE: SD Card insertion depth - by bcnaz - 02-02-2022, 08:02 AM
RE: SD Card insertion depth - by nristen - 02-03-2022, 01:27 PM
  Anyone yet received replacement sim/sd card holder tckosvic 19 9,273 06-16-2023, 12:20 PM
Last Post: fxc
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 2,763 03-26-2023, 02:55 AM
Last Post: tux_life
  PinePhone Pro Motherboard with sim card holder tckosvic 1 1,643 08-22-2022, 06:42 PM
  Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro ANDROID2468 11 7,736 06-15-2022, 02:32 AM
Last Post: fxc
  Replace PPP sim card/sd card slot hardware tckosvic 5 4,188 03-13-2022, 12:20 PM
Last Post: tckosvic
  How to remove the sim card liberty1234 6 4,345 02-16-2022, 01:27 PM
Last Post: ragreenburg
  Bent SD card pin bhboyle 5 3,558 02-03-2022, 09:54 AM
Last Post: kqlnut
  SD card slot specs frimmel 3 2,811 01-27-2022, 09:48 PM
Last Post: bcnaz
