Keyboard modification - what did I just cut through?
Let's start this with a disclaimer that what I have done is stupid and I am aware of that.
Does anyone have a picture of the traces around the pogo pin section of the keyboard case? You see I've cut through the case pretty close to the short side of that pad array nearest the camera cutout and I can see copper from the PCB. I think the VBUS trace was the only one hit but I can't be sure.
Why did I make the cut? I put an NVMe drive heatsink on the can over the SoC to help with heat, this added to the thickness of the phone so I cut through the back cover to allow it to fit and when I tried to make the same modification to the keyboard I got overzealous. Measure twice cut once!
Edit: the keyboard works but power from keyboard to pinephone doesn't seem to, that supports the damaged vbus theory
Keyboard modification - what did I just cut through? - by CampGareth - 01-22-2022, 01:36 PM
  keyboard case charging but not typing new2pinephone 18 6,044 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 11,083 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 458 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,313 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 481 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,308 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 552 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 649 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,074 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 885 10-11-2023, 09:03 AM
Last Post: elof
