Enabling wifi
(08-02-2016, 02:36 AM)pfeerick Wrote:
(06-30-2016, 05:20 AM)c4tich Wrote: I made the proposed changes and it doesn't work, the command sudo iwconfig wlan0 gives the following output
wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Failed to bring up wlan0.
Sorry for not getting back to you sooner c4tich. I'm assuming you didn't make any progress as you didn't come back with a suitably joyous response Wink
Sounds more like it's something wrong with the /etc/wpa_supplicant/wpa_supplicant.conf file. Double check that it is formatted correct, and there aren't any missing quotation marks or braces - they are always in matching pairs - one to open and one to close.
Otherwise, try a simpler version of it with just the network ssid and psk.
network={
ssid="Wireless Network Name"
psk="network-password"
Also, so you get any response'sudo iwconfig'? Does it at least indicate that the wireless module is functioning?
@hawk: Glad you got your wireless up and running, it certainly makes life easier when you can use wifi instead of wired connections!
Hey,
I'm not the OP but I am someone who is experiencing the same exact problem! I did your changes and I'm still failing here. Sudo iwconfig shows "no wireless extensions" for eth0, dummy0, sit0, and lo...
What should my next steps here be?
Also, I've attached an image just to verify that I in fact plugged in the wifi chip to the appropriate place, lol. All pins are in, but it does feel loose....
Enabling wifi - by c4tich - 06-29-2016, 10:50 AM
RE: Enabling wifi - by MarkHaysHarris777 - 06-29-2016, 12:15 PM
RE: Enabling wifi - by c4tich - 06-29-2016, 12:21 PM
RE: Enabling wifi - by pfeerick - 06-29-2016, 09:55 PM
RE: Enabling wifi - by c4tich - 06-30-2016, 05:20 AM
RE: Enabling wifi - by pfeerick - 08-02-2016, 02:36 AM
RE: Enabling wifi - by workaccountbro - 12-28-2016, 02:22 PM
RE: Enabling wifi - by hawk - 08-01-2016, 10:46 PM
RE: Enabling wifi - by MarkHaysHarris777 - 06-30-2016, 08:07 AM
RE: Enabling wifi - by c4tich - 06-30-2016, 03:35 PM
RE: Enabling wifi - by pfeerick - 06-30-2016, 10:01 PM
  [split] Better WiFi/BT module? moriel5 3 5,056 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 4,759 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 25,059 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 4,175 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 27,122 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 9,744 09-11-2018, 02:02 PM
Last Post: gamelaster
  Installing another WiFi module on one of the buses mido2018 1 3,574 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 15,915 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 6,070 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
Sad wifi direct bj_jung 2 5,412 12-29-2016, 10:26 AM
Last Post: happytuna
